What I/c To Buy
NeedmorePower
  • Replies 330
Posted Images
  • Forged Member
  • Member For: 17y 10m 23d
I have the PWR around battery pipe, and when installed with their intercooler it made a huge difference, the respnse is much better too! definately the way to go unless changing the crossover
  • Member For: 18y
Boost spikes from 15psi to nearly 18psi with the removal of the restrictive stock pipework on my car :roflmbo:
I have recently done this and I had a 3 psi boost spike. After I got the car tuned I got a total of 15rwkw gain. Hope that helps
  • BACK SLOWER THEN EVER!
  • Member For: 17y 5m 27d
Well boys, I finally got the wogcooler and picked up the Plazmaman UBP, now all I need is time to put it in.
I CAN'T WAIT!!!
Ozzie
  • Member For: 19y 5m 22d
I have a wog cooler, fuel pump, injectors and putting a new clutch and metal cat in as soon as the wog gets to WA within a few weeks. I'm also going to do the under battery pipe and K&N panel filter so once it's re-tuned I'll let guys know of the results. It made 267 with dips in the graph because of the clutch slipping. If the valve springs hold and it makes 300 rwkw's I'll be a happy camper :) The wog recommended instructed me to get an UBP... this should together with the cat should also free-up some pressure on the valve springs! hope they hold in there as I'm done spending money lol
You will be happy with the results the only thing you need to add is the tune now to get max performance
All done. Not an easy pipe to fit, lucky I did it at the same time as the cooler.
Unfortunately I can't push it cause its going nuts on factory tune. I need to get a custom asap, I can't drive on boost.
Ozzie
BTW if you going to fit the UBP yourself either ask for instructions of PM me.
quick notes you have to pull of the Drivers side Headlight & battery. Fitting the headlight back into place is difficult.
