What I/c To Buy
NeedmorePower
purely and simply the brackets work on 99% of mki's
the other 1 % needs adjustment due to manufacturing tolerance in the vehicle
in mkii's you need to drill 2 holes
as to why design brackets that dont fit? they do fit! read instructions on my site or ask adam to put up the instructions that were on my sponsor forum! much more concise!
twisted shorter bracket with xtra bend goes to the driver side above the lip but can be used below as well!
  • Replies 330
Posted Images
Are you interested in advising me of these tricks? Pretty please!!!!!!
Hi,
As you may know ive won this Monsta I/C.
I have fitted a PWR aux trans cooler in between my stock I/C and A/C condensor. Its a nice fit.
You advised that there can be some tricks to getting this sort of clearance when fitting the Monza styled I/C? As I need at least 19mm.
Cheers,
Brad.
this is not my product so really the info I give is cause I am a nice guy unlike some others!
best way to get clearance for the trans cooler is to use the push through ties they come with and tie it to the air cond. condensor as high as posible,
use crimp clamps so there is no chance of the worm rubbing through the condensor etc.
then the radiator support bracket has large adjustment holes youu need to loosen all 4 bolts and push the radiator as far back as posible
then it all fits
  • Into the laaaake
  • Member For: 17y 7m 2d
Cheers.
Thanks for that.
Yeah I used the push through ties that PWR supplied with the transcooler. However I mounted it so it would all clear my stock I/C... Doh!!! So its actually as low as possible......
Ill look into the rad suppport brackets.
Thanks mate!
  • 2 weeks later...
  • Mad Scientist
  • Member For: 20y 1m 18d
I was talking to Danny this morning mate. This is exactly what I am doing. And yes he agreed, this setup is good for 300-315rwkws. :stirthepot:
I am doing the same, already have the cooler, and the upb is here waiting to be installed! :roflmbo:
