  • Replies 108
Posted Images
  • Member For: 19y 4m 4d
Do these bars come with bush replacements, if not what do you guys use, rubber or Urethane... or leave the OEM item on ?????
  • Member For: 20y 9m 3d
for you sedan boys, after reading the writeup by autospeed on the whiteline products it seems the best mod for the rear end is dampers rather than a rear swaybar.
  • Member For: 20y 2m 18d
How much are better dampers though?
I think the best bang for buck seems to be swaybars. I am very happy with how my car handles with these.
should be under $300 a pair id say... definately affordable.
  Wazzup said:
Has anyone fitted the swaybars, both front and rear, to their car?
Is it an easy job or should you get somebody to do it for you?
piece of piss.
you could knock the front over in 20 mins. rear probly the same. very easy
I had to do the front, then remove to get a part fixed under warranty (bent bracket) and replace. The front you can do in about 5 minutes, back probably 3 or 4 - very easy.
  • 1 month later...
