cobrav8 Member 1,969 Member For: 20y 2m 18d Gender: Male Location: New Zealand Posted 27/06/06 01:01 AM Share Posted 27/06/06 01:01 AM Well - go to the whiteline website www.whiteline.com.au and read all the stuff, all of the write ups have front and rear swaybars, and the kits they sell have them as recommended - so, I cant see why Whiteline would say otherwise. Link to comment https://www.fordxr6turbo.com/forum/topic/26406-whiteline-27mm-front-swaybar/page/4/#findComment-399215 Share on other sites More sharing options...
dingah2 Crusty aviator Member 846 Member For: 20y 11m 22d Gender: Male Location: ACT Posted 27/06/06 03:23 AM Share Posted 27/06/06 03:23 AM cobrav8 said: Well - go to the whiteline website www.whiteline.com.au and read all the stuff, all of the write ups have front and rear swaybars, and the kits they sell have them as recommended - so, I cant see why Whiteline would say otherwise.←Totally agree and I canot find my resouces which is annoying - as far as I recall it related to inside wheel lifting if stiffened bar used and the disfunctionality arises from a function of the rear suspension design/mass/inertia. If I can dig it out I will post - that really leaves uprated shox/springs at the rear as options, but currently I quite like the balance as it is noting I have uprated front coil-overs, normal ride height, the 27mm sway bar and run 17s. I guess we should also make mention that many forum folk have gone for more than significant changes to thier running gear already by running with 19s and 20s, lowered springs etc but the T's suspension was never calibrated for such changes of input and response, therefore what suits one car may turn out to be quite inappropiate on another.Suck it and see is the answer, but care should be taken in accepting others' recommendations on equipment solutions as tacit....Dingah Link to comment https://www.fordxr6turbo.com/forum/topic/26406-whiteline-27mm-front-swaybar/page/4/#findComment-399291 Share on other sites More sharing options...
bjcrown Donating Members 182 Member For: 19y 7m 23d Posted 27/06/06 06:21 AM Share Posted 27/06/06 06:21 AM (edited) dingah2 said: Gawwd Jack, what have we started here....time to buy stocks in Whiteline.On a more serious note when researching prior to fitting a 27mm front I too had the same feedback as DesFlurane quotes - ie leave the rear alone as BA/BF rear suspension setup will misbehave with rear stiffened further. That was from Whiteline and somewhere else - so caution folks.Dingah←I'm looking to replace the front swaybar too. My car is stock. So I'd take it that a front swaybar on it's own will do the job - that is without lowering the vehicle or changing shocks/springs. Can someone please advise.Also, what if I decide to lower the vehicle at a later date? Would this type of swaybar cause any problems?Thanks. Edited 27/06/06 06:22 AM by bjcrown Link to comment https://www.fordxr6turbo.com/forum/topic/26406-whiteline-27mm-front-swaybar/page/4/#findComment-399336 Share on other sites More sharing options...
dingah2 Crusty aviator Member 846 Member For: 20y 11m 22d Gender: Male Location: ACT Posted 27/06/06 06:37 AM Share Posted 27/06/06 06:37 AM As you said - try the front sway bar first - 27mm. be a little more circumspect with the rear depending on what outcome you desire.Then you can follow-up with springs shox as you desire. Swaybar mod is compatible physically.Dingah Link to comment https://www.fordxr6turbo.com/forum/topic/26406-whiteline-27mm-front-swaybar/page/4/#findComment-399342 Share on other sites More sharing options...
gfsperformance The Shire's Premium Speed Shop Member 23 Member For: 19y 5d Posted 28/06/06 12:04 AM Share Posted 28/06/06 12:04 AM For those interested in modifying their suspension, here is a list of parts available made by Whiteline Automotive;http://www.whiteline.com.au/YourCar/kits/CK_Falcon_BA.pdf...and here is a short article written by AutoSpeed on Whiteline's modified BA XR6T;http://www.whiteline.com.au/docs/articles/AS_XR6T.pdfRRP's (GFS Performance prices ) can be found at Whiteline's Webstore;https://www.whiteline.com.au/store/Hope this helps.Cheers. Link to comment https://www.fordxr6turbo.com/forum/topic/26406-whiteline-27mm-front-swaybar/page/4/#findComment-399585 Share on other sites More sharing options...
bjcrown Donating Members 182 Member For: 19y 7m 23d Posted 03/07/06 05:07 AM Share Posted 03/07/06 05:07 AM dingah2 said: As you said - try the front sway bar first - 27mm. be a little more circumspect with the rear depending on what outcome you desire.Then you can follow-up with springs shox as you desire. Swaybar mod is compatible physically.Dingah←If I only do the front swaybar (27mm), would I need a wheel alignment? Link to comment https://www.fordxr6turbo.com/forum/topic/26406-whiteline-27mm-front-swaybar/page/4/#findComment-401627 Share on other sites More sharing options...
G6ET8U Playing with Sports Bikes... Silver Donating Members 1,927 Member For: 19y 7m 12d Gender: Male Location: Whistling, GTX. Posted 03/07/06 08:23 AM Author Share Posted 03/07/06 08:23 AM Quote If I only do the front swaybar (27mm), would I need a wheel alignment?As far as my advice goes from the people who fitted mine, no you don't...And I haven't had any adverse effects from not having a wheel alignment...Jack Link to comment https://www.fordxr6turbo.com/forum/topic/26406-whiteline-27mm-front-swaybar/page/4/#findComment-401691 Share on other sites More sharing options...
jordak Member 1,226 Member For: 21y 1d Posted 03/07/06 08:59 AM Share Posted 03/07/06 08:59 AM XR6T8_U said: Quote If I only do the front swaybar (27mm), would I need a wheel alignment?As far as my advice goes from the people who fitted mine, no you don't...And I haven't had any adverse effects from not having a wheel alignment...Jack ←Not required in my case either. Link to comment https://www.fordxr6turbo.com/forum/topic/26406-whiteline-27mm-front-swaybar/page/4/#findComment-401715 Share on other sites More sharing options...
d202008 Member 10 Member For: 20y 4m 20d Location: Melbourne Posted 03/07/06 12:00 PM Share Posted 03/07/06 12:00 PM Hi JackWhere in Ferntree Gully did you fit yours?? ThanksD Link to comment https://www.fordxr6turbo.com/forum/topic/26406-whiteline-27mm-front-swaybar/page/4/#findComment-401829 Share on other sites More sharing options...
G6ET8U Playing with Sports Bikes... Silver Donating Members 1,927 Member For: 19y 7m 12d Gender: Male Location: Whistling, GTX. Posted 03/07/06 12:25 PM Author Share Posted 03/07/06 12:25 PM Mr Muffler on Burwood Highway...Nice bloke in there too... very easy to deal with! They also fitted the cat on my car too...Jack Link to comment https://www.fordxr6turbo.com/forum/topic/26406-whiteline-27mm-front-swaybar/page/4/#findComment-401844 Share on other sites More sharing options...
