  • Replies 30
  • Member For: 18y 8m 21d
Where abouts in the advanced settings of the Arcade VGA card do you configure the settings below:
NTSC - Horizontal Freq - 15.734 kHz, Vertical Freq - 59.94 Hz, Colour Freq - 3.579 MHz, Refresh Rate - 60Hz
Do you mannually configure these or is there a preset which configures this for you?
Aaron
  • Member For: 21y 3d
Aaron
If you are using the Arcade VGA card, you don't have to do any configuration changes. Simply install the Windows XP Driver and that's it.
If you want to get real flash you can install the toolbox program but it is not necessary
Panda
Aaron
Panda
I see what you mean. The Arcade VGA just sorts itself out. I've got it displaying quite nicely now. The width of the display is perfect but, it seems to be hiding the bottom section of the windows desktop when set at 640 x 480. Is it possible to get the ICC screen to display the entire windows desktop? What resolution are ppl using and how do you set it?
Aaron
Aaron
I have the same problem. The only way to fix it is to install the 'ATI Control Panel' off the CD that came with the Arcade VGA Card.
Theis will give you the ability to move the screen around, resize etc
The only resolution you can have is 640x480
Panda
  • voy74656
  • Member For: 21y 4m 29d
Hiya! im seriously looking @ this kinda setup for precious pretty soon - right after harvest is over.
Is this where u got your ArcadeVGA cards from???
http://www.ozstick.com.au/prod_interface.html
Everything else seems pretty self explanatory....but im sure I'll have questions when I get into it.
  • Member For: 20y 6m 4d
I found it cheaper to buy from the ultimarc website in the US. Also when I looked the Aus site only had the crappy ver.1 card advertised(AGP Only & single output I think).
Got mine from the US site - HERE - Only took a week to ship... :spoton:
Chris :spoton:
Got mine from the US site - HERE - Only took a week to ship...  :laughing:
Chris :laughing:
It does look a bit better - PCIE, dual output, normal monitor compatible - AND CHEAPER?? What a bargain - thanks for the info
Panda
