  • Member For: 19y
  Panda said:
What card are you using?
Panda
geforce 2mx400 :spoton:
I've got a gf4 ti4200 sitting around somewhere which I will try, but otherwise I may have to bite the bullet and buy the arcade vga card
  • Replies 30
  • Member For: 21y 21d
  qwigybo said:
geforce 2mx400
Did a bit of a search on this card and it seems a bit under-whelming
I used the nVidia Geforce 4 and did not get satisfactory results. The advanced settings were in - Control Panel -> Display -> Settings -> Advanced -> Advanced Timing Settings
I had to make the Screen Size 640 x 480 and that would give me a good picture, however, when I restarted the carputer it always went back to the split screen.
  qwigybo said:
I will have to bite the bullet and buy the arcade vga card
I wish I had just done this from the start!! More money, but far less headaches
Panda
  • Member For: 19y
ok I spent about 4hrs playing with the settings on the gf2 last night, I have it displaying nicely, only problem I have it that I have to use the mouse to scroll around to see the whole desktop.... seems to be "oversized" for a full desktop display on the screen. those wanting to use an nvidia card I used the following settings in the advanced timing.
horizonal pixels: front: 40 back: 56 sync pol: - front-end: 480 sync width: 64
vertical lines: front: 5 back: 15 sync pol: - front-end: 240 sync width: 3
refresh rate: 60.054
can you remember what settings you used for the gf4 panda, from memory you managed to get the full screen to display
Edited by qwigybo
I know I had the same problem, and from memory I had to change the 'front porch' size to 640x480 pixels in the 'Advanced Timing' options.
Hastle is, I could set it to that value and every time I went to standby or turned the carputer off, it would reset to the default values.
Panda
  • boosting
  • Member For: 18y 10m 12d
Hay Panda,
Firstly great job!
I now have a couple of really dumb questions so sorry in advance.
1. Do you use a Laptop or a desktop type computer? and if using a desktop do you just run lines which are long enough to the boot or something??
2. Is there some like connector at the back of the ICC where you plug the cable in, once made. Similar to the AUX cable (which I got installed)
3. to get sound do you run the AUX from the carputer right??
4.Once the cable is done, do you just plug it all in ie. into the computer monitor output and into the ICC?? then obviously change the settings via control panel for video (as stated above)
I am in NZ so yeah I haven't heard of anyone do this before in a BA.
Thanks for your help mate
Modified desktop
Yes, the video, sound, USB, InfraRed all have to run from the boot to the front of the car.
The AUX connector you are talking about is what the audio goes to, the video goes into the DVD / SatNav plug on the ICC (only in the Premium Audio)
Yep
I don't want to over-simplify the install, but yeah, that's about it
I was surprised to find that many people have done this before. I read every carputer post on this and other forums to learn what I know now
Panda
  • boosting
Cheers mate
I think I may start to gather all the parts to make one now!
Seems like a better idea than modifying the ICC to play DVDs as if the carputer can at least hold my mp3s and the video files.
The most valuable piece of advice I could give you is to get an Arcade VGA card. Easily the best video card for the BA-BF
Panda
  • 1 month later...
  • 3 weeks later...
