Rab WOT? Moderating Team 10,981 Member For: 12y 4m 7d Gender: Male Location: Frankston, 3199 Posted 09/08/16 02:17 AM Share Posted 09/08/16 02:17 AM (edited) Was sublime Soft as a baby's bum and fantastic flavour. Didn't weigh it :( Cooker was stabilised at about 225f Meat was on for about an hour 20 (indirect heat) - pulled it off @120f, cranked up the coals (to and put it back on over the flame to crisp up the bacon and get the internal up to around 135f Basted the bacon with a brown sugar/hickory sauce for the last 5 mins. Sliced it pencil thick, topped with some bacon bits that broke off and it all mingled perfectly. Cranberry jelly worked awesome as an accompaniment. Only thing I'd do differently would be to add some water chestnuts to the bacon I threw on top when serving up - I reckon they would have topped it perfectly. Was my first try at the "bacon weave" and second time cooking venison (first time was a standard roast in the oven about a decade ago) so was a bit nervous (I know how bad the meat can turn out). Record of the cook if interested in BBQ diagnostics : https://myflameboss.com/cooks/36131 edit: next time I'll butterfly the strip and roll it with some stuffing - am thinking creme cheese, shallots and some peppers then wrap it in the bacon edit2: make sure you get "streaky bacon" if you want to try the wrap - nice long, straight cuts rather than the more usual middle rashers Edited 09/08/16 02:25 AM by Rab 2 Link to comment https://www.fordxr6turbo.com/forum/topic/26403-whats-on-the-menu/page/126/#findComment-1606511 Share on other sites More sharing options...
camo86T Silver Donating Members 1,810 Member For: 11y 4m 21d Gender: Male Location: SW Sydney Posted 09/08/16 03:37 AM Share Posted 09/08/16 03:37 AM Epic stuff Rab! Link to comment https://www.fordxr6turbo.com/forum/topic/26403-whats-on-the-menu/page/126/#findComment-1606522 Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,332 Member For: 19y 9m 10d Gender: Male Location: Perth Posted 09/08/16 03:39 AM Share Posted 09/08/16 03:39 AM 1 hour ago, Rab said: W Cooker was stabilised at about 225f edit2: make sure you get "streaky bacon" if you want to try the wrap - nice long, straight cuts rather than the more usual middle rashers This gets me all the time. Mine rises slowly and tricks you into thinking it's stabilised then will spike once you put the food in. I think the time it's open must draw enough draft to get the charcoal all stirred up. Link to comment https://www.fordxr6turbo.com/forum/topic/26403-whats-on-the-menu/page/126/#findComment-1606523 Share on other sites More sharing options...
Rab WOT? Moderating Team 10,981 Member For: 12y 4m 7d Gender: Male Location: Frankston, 3199 Posted 09/08/16 03:51 AM Share Posted 09/08/16 03:51 AM (edited) Are you using anything to control the temp? Mine drops when I open the lid - If I let it react to the temp change then it'll stoke the fire. (have set it to pause for 4 mins when it registers the door has been opened) I also found (depending on the temp needed) only lighting the charcoal in 2 small spots (for a 225f cook) helps it keep stable (1 spot it fluctuates throughout the cooks, 3 spots or more it's too easy to run away) You may be lighting too much charcoal at the start, causing it all to be starving for oxygen - when you open the lid it's able to get as much as it wants and the whole lot can heat up. Edited 09/08/16 03:53 AM by Rab Link to comment https://www.fordxr6turbo.com/forum/topic/26403-whats-on-the-menu/page/126/#findComment-1606525 Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,332 Member For: 19y 9m 10d Gender: Male Location: Perth Posted 09/08/16 03:56 AM Share Posted 09/08/16 03:56 AM Just the top and bottom vents and charcoal placement to control temp. Mine drops intially but then roars up once the lid is closed. I cooked some steak on it last night and used a handful for charcoal and it still does it. Link to comment https://www.fordxr6turbo.com/forum/topic/26403-whats-on-the-menu/page/126/#findComment-1606526 Share on other sites More sharing options...
Rab WOT? Moderating Team 10,981 Member For: 12y 4m 7d Gender: Male Location: Frankston, 3199 Posted 09/08/16 04:04 AM Share Posted 09/08/16 04:04 AM Have you got a temp probe at meat level? Try it with the deflector plate in one time and see if the grill temp also rises significantly. The radiant heat from the coals can increase once they go redder from the air, but the pit temp seems to stay stable (if that makes sense) - an unprotected dome thermometer will jump up from the hotter air, while the temp at the grill won't move much Link to comment https://www.fordxr6turbo.com/forum/topic/26403-whats-on-the-menu/page/126/#findComment-1606529 Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,332 Member For: 19y 9m 10d Gender: Male Location: Perth Posted 09/08/16 04:11 AM Share Posted 09/08/16 04:11 AM Yeah I have a probe but don't bother using it for steaks etc. I don't used the dome Temp gauge as it's proven itself to be fairly inaccurate. I'll give the deflector plate ago. Wifey is keen to do a chunk of pig for pulled pork dishes so don't want to cremate it. Thanks for the tips! Link to comment https://www.fordxr6turbo.com/forum/topic/26403-whats-on-the-menu/page/126/#findComment-1606531 Share on other sites More sharing options...
Rab WOT? Moderating Team 10,981 Member For: 12y 4m 7d Gender: Male Location: Frankston, 3199 Posted 20/08/16 02:19 AM Share Posted 20/08/16 02:19 AM Have a tray of snags near useby and new charcoal so I want to get rid of the old stuff. Decided to have a try of deviled sausages. Will be for lunch - can always cancel them if they're a failure and get something else for dinner;) Dozen snags are under the sauce and apples/onions - fingers crossed it works Link to comment https://www.fordxr6turbo.com/forum/topic/26403-whats-on-the-menu/page/126/#findComment-1608314 Share on other sites More sharing options...
discostig Manual mode ________________________ All day, erryday Donating Members 13,798 Member For: 17y 7m 8d Gender: Male Location: Probably above atmospheric pressure Posted 20/08/16 04:35 AM Share Posted 20/08/16 04:35 AM Just put on a frozen curry pie and frozen crumbed fish in the lower oven Living the dream 5 Link to comment https://www.fordxr6turbo.com/forum/topic/26403-whats-on-the-menu/page/126/#findComment-1608335 Share on other sites More sharing options...
masda74 To Loud Gold Donating Members 4,112 Member For: 13y 7m 2d Gender: Male Location: WA, Perth Posted 20/08/16 05:17 AM Share Posted 20/08/16 05:17 AM Rab, if you leave the rims on the table all day, everyday and all night. Can I have your home address please? Link to comment https://www.fordxr6turbo.com/forum/topic/26403-whats-on-the-menu/page/126/#findComment-1608345 Share on other sites More sharing options...
