faygun Member 389 Member For: 21y 11m 23d Gender: Male Location: Sydney Posted 19/06/06 11:07 AM Share Posted 19/06/06 11:07 AM Hey Guys,Sorry tried searching for it and no decent info came up.I have got an air/fuel ratio gauge and a voltmeter in an SS pod, I am not sure if they are mechanical or electrical, (they only have a few short cables coming out of them, im guessing they are electrical). they are the cobalt series.how hard is it to hook these up? do u know any one in sydney who can easily do these?thanks guys Link to comment https://www.fordxr6turbo.com/forum/topic/26279-how-to-hook-up-an-air-fuel-ratio-and-voltmeter/ Share on other sites More sharing options...
RIC21T Member 22 Member For: 19y 2m 20d Posted 19/06/06 11:11 AM Share Posted 19/06/06 11:11 AM faygun you should go to Autotect they will install you air/fuel ratio gauge and a voltmeter Link to comment https://www.fordxr6turbo.com/forum/topic/26279-how-to-hook-up-an-air-fuel-ratio-and-voltmeter/#findComment-396671 Share on other sites More sharing options...
ZAP No boost, no bottle, just my foot on the throttle! Lifetime Members 7,935 Member For: 21y 4m 20d Gender: Male Location: Sydney Posted 19/06/06 12:03 PM Share Posted 19/06/06 12:03 PM I am not going to tell you how to do it as a AFR gauge needs to be connected to a Pyro sensor that is welded and tapped into the exhaust manifold. the volt gauge can be attached to any + and - in the car, but a direct connection tot he battery is the best.By the way both gauges are totally useless and will not give you any valid data. I would go and get oil temp or pressure and boost. Link to comment https://www.fordxr6turbo.com/forum/topic/26279-how-to-hook-up-an-air-fuel-ratio-and-voltmeter/#findComment-396687 Share on other sites More sharing options...
faygun Member 389 Member For: 21y 11m 23d Gender: Male Location: Sydney Posted 19/06/06 12:12 PM Author Share Posted 19/06/06 12:12 PM I am not going to tell you how to do it as a AFR gauge needs to be connected to a Pyro sensor that is welded and tapped into the exhaust manifold. the volt gauge can be attached to any + and - in the car, but a direct connection tot he battery is the best.By the way both gauges are totally useless and will not give you any valid data. I would go and get oil temp or pressure and boost.←thank you for that. I got these for a good price so I want to use them as well. I am running an N/A XR6 so boost is out of the question but I will get an oil pressure gauge as well. Link to comment https://www.fordxr6turbo.com/forum/topic/26279-how-to-hook-up-an-air-fuel-ratio-and-voltmeter/#findComment-396690 Share on other sites More sharing options...
ZAP No boost, no bottle, just my foot on the throttle! Lifetime Members 7,935 Member For: 21y 4m 20d Gender: Male Location: Sydney Posted 19/06/06 12:13 PM Share Posted 19/06/06 12:13 PM faygun, I did not want to burst your bubble, but AFR gauges are just disco lights for the dash and will not give you any usable info.As for the volt meter, this would have to be as useful as an amp gauge.If you want details on AFR installs search pyro or wideband Link to comment https://www.fordxr6turbo.com/forum/topic/26279-how-to-hook-up-an-air-fuel-ratio-and-voltmeter/#findComment-396692 Share on other sites More sharing options...
faygun Member 389 Member For: 21y 11m 23d Gender: Male Location: Sydney Posted 19/06/06 12:55 PM Author Share Posted 19/06/06 12:55 PM faygun, I did not want to burst your bubble, but AFR gauges are just disco lights for the dash and will not give you any usable info.As for the volt meter, this would have to be as useful as an amp gauge.If you want details on AFR installs search pyro or wideband←nah its all good mate okay I will do a search. thank u Link to comment https://www.fordxr6turbo.com/forum/topic/26279-how-to-hook-up-an-air-fuel-ratio-and-voltmeter/#findComment-396720 Share on other sites More sharing options...
Max Power Member 381 Member For: 21y 2m 2d Location: MENAI, NSW Posted 20/06/06 02:11 AM Share Posted 20/06/06 02:11 AM Your A/F gauge source wire is the solid grey one coming out of the O2 sensor in the dump pipe. You should be able to see it on the drivers side near the firewall. Link to comment https://www.fordxr6turbo.com/forum/topic/26279-how-to-hook-up-an-air-fuel-ratio-and-voltmeter/#findComment-396809 Share on other sites More sharing options...
cobrav8 Member 1,969 Member For: 20y 3m 11d Gender: Male Location: New Zealand Posted 20/06/06 02:22 AM Share Posted 20/06/06 02:22 AM I agree with Mx Power - you can piggy back on the factory sensor - no need for a new one.though - I also agree with Zap- it is about as useful as a disco light - I have one, and ended up adding a switch so that it can be swicthed off most of the time. Link to comment https://www.fordxr6turbo.com/forum/topic/26279-how-to-hook-up-an-air-fuel-ratio-and-voltmeter/#findComment-396815 Share on other sites More sharing options...
faygun Member 389 Member For: 21y 11m 23d Gender: Male Location: Sydney Posted 20/06/06 02:26 AM Author Share Posted 20/06/06 02:26 AM thank u for that guys =)will hook them up this weekend hopefully Link to comment https://www.fordxr6turbo.com/forum/topic/26279-how-to-hook-up-an-air-fuel-ratio-and-voltmeter/#findComment-396816 Share on other sites More sharing options...
PSYCHO XRT THE PSYCHO XRT Donating Members 1,275 Member For: 19y 6m 26d Gender: Not Telling Location: At the lights! Posted 22/06/06 08:48 AM Share Posted 22/06/06 08:48 AM thank u for that guys =)will hook them up this weekend hopefully←the AFR gauge of urs, is that a digital one?? Or is that the ones withthe led readings? Link to comment https://www.fordxr6turbo.com/forum/topic/26279-how-to-hook-up-an-air-fuel-ratio-and-voltmeter/#findComment-397536 Share on other sites More sharing options...
