  • Member For: 21y 2m 25d
do u need to connect like a mouse or keyboard
There are various possibilities for input devices. For the mouse you could have -
- touchscreeen overlay
- wireless mouse
- wireless trackball
- joystick
- touchpad
And for the keyboard you could have -
- wireless keyboard
- on screen keyboard
Or you could have a keyboard with an integrated mouse / joystick
Many options, personally, to keep the car looking stock, I'm going to have a touchscreen overlay over the top of the factory ICC, and just use the On Screen Keyboard when the need arises
Panda
  • Replies 44
Can it work on any screen, not just the factory icc
Yes, it is actually easier to make it work on an aftermarket screen. The reason I chose to make it display on the factory screen was to keep it looking stock, and it also meant that I did not have to fork out for the screen as well (about $300-$400)
Panda
  • 6 months later...
I've been playing around with my carputer and I thought I might post up some pics.
I was never really happy with my first effort at building the case, it did the job but looked cheap. (hell, it was cheap)
I have made a new case, similar but better. This one is slightly higher (120mm instead of 80mm) because I figure there is no point saving space above the carputer, you can't put anything on top of it anyway. This allows me to use a bigger fan 120mm instead of 80mm (106CFM as opposed to 65CFM) and it also means that I don't have to limit myself to low profile PCI cards now.
Please bear in mind, this is just a mock up - I know it needs cleaning up.
Empty Case
Case with M/B
Case with M/B and fan
Case with M/B, fan and PCI cards
Case with M/B, fan, PCI cards and HDD
Case with M/B, fan, PCI cards, HDD and DVD
I wasn't going to have a DVD, but for the sake of ease I decided to put one in, plus I found it cheap on eBay. (only $10 + $6.80 postage - bargain)
This is how I was going to have it before getting the DVD
Anyway, this is the finished product from the top.
There's a bit of room on the top right corner, I might stick another 120mm fan in there. That's it for now, but I'm sure this will change again soon.
Panda
  • 1 month later...
  • Member For: 18y 4m 1d
Thanks to panda I have finally tested my carputer on the ICC screen using the arcadevga agp video card with no problems.
I have made the audio & video cables myself using the correct plugs. The entire unit will fit under the dash out of site and be powered by a M2-ATX, 160w output, 6v to 24v wide input Intelligent Automotive DC-DC Car PC Power Supply.
As for the dvd player, that will be a small portable usb type with a slot instead of a drawer.
  • 4 months later...
  • Member For: 20y 14d
What res do you run on the arcadevga card and the ICC, and what config do you need to do to make it all work. I have the card running now just aint plugged it into the car, cos I dont wanna blow up my icc.
Cheers
Nathan
Edited by Demonio
