Carputer In Xr6 Turbo
Panda
  • Member For: 19y 4m 9d
Touchscreen!!!  :w00t:
How much?
Parts cost approx $350ish .... I have to source another supplier.. Althought, The touchscreen is only for the CAR PC.. rather than for the Ford radio / A/C
Danny.
  • Replies 44
  • Member For: 20y 8m 7d
Where you got power from
I have a 'tank' battery in the boot (second photo in the first post). It only charges when the key is in the ACC position. This way if I forget to turn the carputer off, it won't kill the cars battery.
<div class='bbimg'>
</div>
The power supply is a 300Watt 12Volt unit from here 300W PSU
You can just see it under the carpet in the top / left corner of the boot. (first photo in the first post)
where you have installed the computer
I currently have the box sitting on the carpet in my boot (first photo in the first post) because it is running quite hot, but I built it as small as possible so I can put it inside the spare tire under the carpet (temperature allowing).
what your interface is
I currently have a NVidia Geforce 4 Video card, but after receiving some information from Hedsex regarding the Arcade VGA Video Card, I have ordered one of these and it will be much better....no more playing with video card settings.
Panda
Edited by Panda
...in terms of power supply... pc will not brownout when cranking to start engine...It will also turn on, and turn off your pc based on a Ignition input (you could use the Remote Power from your head unit as I've done in the past).
Although its only 90 watt, there is also a 160watt version.. these are not designed for P4 based processors, but rather VIA based EPIA Boards..
Yeah, I had a look at them but didn't want to be limited by power so I got a 300W PSU (link in the previous thread)
...Everything you would want is at www.mp3car.com's forums
been a member for a while now
...Ohh, and just so you know, I am also able to convert the Ford ICC to touchscreen
I plan to put a touchscreen overlay over the top of the factory screen, only about $180 from HERE
<div class='bbimg'>
</div>
Panda
Edited by Panda
Panda
Ohh Goodie, you done the hard work for me.. that's definatly cheaper than the one I sourced previously..
Danny.
  • Member For: 19y 6m 9d
That touch screen kit you linked to might be a bit big for the ICC screen as it says it is for an 8" monitor.
You might do better with something more like this
good luck with it though, I will follow your progress closely, I'm looking to start on mine soon.
Glad it helped, it's reward for you helping me find the Arcade VGA card.
Panda
Yeah that's right.. On initial checking that website, I expected there was other sizes..
but yeah, the one I used width was perfect, height was bigger, but hidden behind..
Althought, the IR Reciever above needs "modification" for it to fit.
Danny.
  • 2 weeks later...
Arcade VGA card works a treat, just plug it in and let it go.
<div class='bbimg'>
</div>
<div class='bbimg'>
</div>
Panda
told ya it was easy :)
Did you buy it from chris @ ozstick?
now all you need is the touchscreen membrame (6.4" one, unless you can find a widescreen version which fits perfectly)
Danny.
