shockF6 Member 478 Member For: 19y 3m 22d Location: Melbourne Posted 25/06/06 02:50 AM Share Posted 25/06/06 02:50 AM Well, I've got it working. After many hours of manually changing settings on the Video Card, I finally jagged the correct values.Here's the results<div class='bbimg'></div>Love it!!!Panda←Great Job Panda so spill your guts, how did you get it going :rokon: Link to comment Share on other sites More sharing options...
Panda Member 225 Member For: 20y 9m 14d Gender: Male Location: Gladstone, QLD Posted 25/06/06 08:23 AM Author Share Posted 25/06/06 08:23 AM so you just play mp3's or videoclips through the PC and u get all sounds to the car? Yep, Windows Media Player plays the music and DVD's (I've got about 7500 songs in MP3 format as well as about 100 DVD's in DVIX format) and the carputer outputs to the cars speakers.That is the basic setup, from here I will add OBDII (on-board diagnostics) to be able to interface with the cars computer, GPS / SatNav, Phone Control etc. For now I am happy to be able to see the damn thing correctly.so spill your guts, how did you get it goingShort version - trial and error. Long Version - A normal monitor 'tells' the video card what resolution it can handle, so everything is done automatically.The ICC screen doesn't have that function, you have to input all of the variables manually. So I spent hours changing one variable after the other and eventually got it right.Panda Link to comment Share on other sites More sharing options...
physh Member 248 Member For: 22y 3m 15d Location: Canberra Posted 26/06/06 02:00 AM Share Posted 26/06/06 02:00 AM So post up the specs of the screen! ...and how are you doing the OBDII functionality, and what can it do? Link to comment Share on other sites More sharing options...
Panda Member 225 Member For: 20y 9m 14d Gender: Male Location: Gladstone, QLD Posted 26/06/06 03:22 AM Author Share Posted 26/06/06 03:22 AM So post up the specs of the screenWell, that's a bit of a problem. Since taking the previous photo and posting it here, I have since discovered that if I turn the computer off or put it on standby, when I resume it goes back to the split-screen display. Still work to be done how are you doing the OBDII functionality, and what can it do?That is one of the future plans. At the moment though I am researching a few different boxes -- OBD All In One- This Oneplus a few others that I don't have links to off-hand.As to your question "What can it do?" it simply monitors your on-board computer. From that data, you can datalog all of the information - revs / temperature / A-F Ratios / boost etc etc etc.Panda Link to comment Share on other sites More sharing options...
loopism Tractor Driver Member 709 Member For: 18y 11m 17d Gender: Male Location: Sydney Posted 27/06/06 01:06 AM Share Posted 27/06/06 01:06 AM so spill your guts, how did you get it goingShort version - trial and error. Long Version - A normal monitor 'tells' the video card what resolution it can handle, so everything is done automatically.The ICC screen doesn't have that function, you have to input all of the variables manually. So I spent hours changing one variable after the other and eventually got it right.Panda←... and the values are?????????????????? Link to comment Share on other sites More sharing options...
Headsex Donating Members 2,528 Member For: 19y 5m 15d Gender: Male Location: Melb Posted 27/06/06 01:59 AM Share Posted 27/06/06 01:59 AM As well as needing a combined H+V Sync, the Monitor is only 15khz, Not 30khz like normal PC monitors..A simple method would be to purchase a "Ultimarc ArcadeVga" http://www.ultimarc.com/avgainf.htmlor get a convertor which converts to CGA (yes, cga). as Cga supports 15khz sync. (Cant remember the website that does sells the convertor)And your end result is thishttp://dannyshosting.com/gallery/carpc/DCP_0606Danny. Link to comment Share on other sites More sharing options...
Panda Member 225 Member For: 20y 9m 14d Gender: Male Location: Gladstone, QLD Posted 27/06/06 08:43 AM Author Share Posted 27/06/06 08:43 AM A simple method would be to purchase a "Ultimarc ArcadeVga" http://www.ultimarc.com/avgainf.htmlDamnit, I looked for ages for the Arcade VGA card, but because I couldn't find one I went for the next best thing. Needless to say, immediately after posting this, I will be ordering an Arcade VGA card.Thank you for your help, you've got no idea how much I have searched for this! Love the pictures of your carputer BTWPanda Link to comment Share on other sites More sharing options...
travis Member 25 Member For: 19y 11m 3d Posted 27/06/06 11:23 AM Share Posted 27/06/06 11:23 AM would love some specs on your setup. Where you got power from, where you have installed the computer, what your interface is etc. Keep up the good work! Link to comment Share on other sites More sharing options...
Headsex Donating Members 2,528 Member For: 19y 5m 15d Gender: Male Location: Melb Posted 27/06/06 12:39 PM Share Posted 27/06/06 12:39 PM (edited) A simple method would be to purchase a "Ultimarc ArcadeVga" http://www.ultimarc.com/avgainf.htmlDamnit, I looked for ages for the Arcade VGA card, but because I couldn't find one I went for the next best thing. Needless to say, immediately after posting this, I will be ordering an Arcade VGA card.Thank you for your help, you've got no idea how much I have searched for this! Love the pictures of your carputer BTWThat car pc is not mine, althought I have "near" identical hardware sitting here for mine. We used a vga -> composite 15khz convertor with decent results. since the motherboard we used is tiny, there is no AGP for the arcade vga card. its onboard.Hehe.. Well, I do own a Arcade VGA, however, this is what its used in ...http://dannyshosting.com/gallery/mame?page=3although those pictures were taken before I recieved the card.. www.ozstick.com.au sells the card here in victoria.. (Speak to Chris)..Also, In terms of power, I have what they call a M1-ATX power supply. http://www.mp3car.com/store/product_info.p...&products_id=67it has full 6volt to 24volt input range (yes, pc will not brownout when cranking to start engine).. It will also turn on, and turn off your pc based on a Ignition input (you could use the Remote Power from your head unit as I've done in the past).Although its only 90 watt, there is also a 160watt version.. these are not designed for P4 based processors, but rather VIA based EPIA Boards.. Everything you would want is at www.mp3car.com's forumsOhh, and just so you know, I am also able to convert the Ford ICC to touchscreen (but its expensive to do so...)But.. Just to tease you a little Danny. Edited 27/06/06 12:42 PM by Headsex Link to comment Share on other sites More sharing options...
physh Member 248 Member For: 22y 3m 15d Location: Canberra Posted 27/06/06 11:07 PM Share Posted 27/06/06 11:07 PM Touchscreen!!! :w00t: How much? Link to comment Share on other sites More sharing options...
