Panda Member 225 Member For: 20y 10m 24d Gender: Male Location: Gladstone, QLD Posted 12/06/06 01:09 PM Share Posted 12/06/06 01:09 PM Hi There,I've got a carputer running in my BF XR6 Turbo. Here's a couple of pictures -Everything is working fine (MP3, DVD, GPS) but the display is screwed up, this is what I've got -The display is vehicle specific - it has to be 640x480 resolution with a refresh rate of 60 Hz (which is what I have it set to)The display has to be in NTSC, but I've got my VGA cable running into the factory input which seems to work OK with the Red/Blue/Green signal, perhaps the Sync is wrong (I have connected the H-Sync with the V-Sync to make a combined Sync signal)Any ideas on where I have gone wrong??Thanks,Panda Link to comment Share on other sites More sharing options...
shockF6 Member 478 Member For: 19y 5m 4d Location: Melbourne Posted 12/06/06 01:17 PM Share Posted 12/06/06 01:17 PM the screen is not able to take a VGA signal. It is only intended for a TV style RGB NTSC signal.what you need to do is combine both your H&V syncs to NTSC's 60hz. this will then give you the picture your after.also you may find that a res of 720x480 may fit the screen better as it is a wide screen Link to comment Share on other sites More sharing options...
Panda Member 225 Member For: 20y 10m 24d Gender: Male Location: Gladstone, QLD Posted 12/06/06 01:31 PM Author Share Posted 12/06/06 01:31 PM the screen is not able to take a VGA signal. It is only intended for a TV style RGB NTSC signal.what you need to do is combine both your H&V syncs to NTSC's 60hz. this will then give you the picture your after.also you may find that a res of 720x480 may fit the screen better as it is a wide screen ←I have this picture of a H-Sync + V-Sync to Composite Sync converter -But if I can avoid having to do this it would be great.Thanks for the tip on the 720x480Panda Link to comment Share on other sites More sharing options...
Iconic Bionic My engine bay is Bionic Donating Members 3,726 Member For: 18y 11m 17d Gender: Male Location: Freeways Posted 13/06/06 12:11 PM Share Posted 13/06/06 12:11 PM Hmm. Very interesting but I have no idea what the hell your on about.Good luck. :rokon: Link to comment Share on other sites More sharing options...
shockF6 Member 478 Member For: 19y 5m 4d Location: Melbourne Posted 13/06/06 12:20 PM Share Posted 13/06/06 12:20 PM I have this picture of a H-Sync + V-Sync to Composite Sync converter -<div class='bbimg'></div>But if I can avoid having to do this it would be great.←If you find a way to do it without combining the syncs then please let me know. I have been told by a mate that you can "fool" the syncs into giving the correct combined value by having really odd ball sync settings on the VGA side. That being said, he has never been able to shown me that it actually works and has since built a cct not too dissimilar to the one you listed above. :rokon: Link to comment Share on other sites More sharing options...
SHOCK Team Grandpa Donating Members 1,921 Member For: 18y 10m 6d Gender: Male Location: Hunter Valley Posted 13/06/06 12:53 PM Share Posted 13/06/06 12:53 PM wtf...... Link to comment Share on other sites More sharing options...
spoonage Long Member Member 169 Member For: 20y 19d Location: Canberra, ACT Posted 18/06/06 11:06 PM Share Posted 18/06/06 11:06 PM http://www.trianglecables.com/cotovicovgad.htmlWould that be suitable? Link to comment Share on other sites More sharing options...
Panda Member 225 Member For: 20y 10m 24d Gender: Male Location: Gladstone, QLD Posted 19/06/06 10:31 AM Author Share Posted 19/06/06 10:31 AM I'm not sure if that would do the job.I'm waiting on a new video card which is meant to do the job (however, the one I bought was also meant to be OK for this application) so will let you all know how I go.Panda Link to comment Share on other sites More sharing options...
Panda Member 225 Member For: 20y 10m 24d Gender: Male Location: Gladstone, QLD Posted 25/06/06 12:05 AM Author Share Posted 25/06/06 12:05 AM Well, I've got it working. After many hours of manually changing settings on the Video Card, I finally jagged the correct values.Here's the resultsLove it!!!Panda Link to comment Share on other sites More sharing options...
Trough Lolly Member 4,349 Member For: 20y 6m Gender: Male Location: Mildura Posted 25/06/06 12:17 AM Share Posted 25/06/06 12:17 AM haha good work! so you just play mp3's or videoclips through the PC and u get all sounds to the car? great setup! Link to comment Share on other sites More sharing options...
