igsta Member 371 Member For: 21y 3m 13d Gender: Male Location: Sydney Posted 12/06/06 06:29 AM Share Posted 12/06/06 06:29 AM I took my car in for its 45k service to Ford. My car up until the service has been going the best its ever been. Take the car home re-flash to 305rwkw tune and now the car feels less responsive and more sluggish, especially light throttle accelaration. It seems I need more throttle than before when cruising. I re-flashed again in case I flashed the wrong tune or something but its still the same. All hoses etc have been checked. Boost seems normal as per my gauge. What could Ford have possibly done for my car to feel like this. Link to comment Share on other sites More sharing options...
Turbo6man Lifetime Members 4,084 Member For: 22y 3m 12d Gender: Male Location: South Coast NSW Posted 12/06/06 06:51 AM Share Posted 12/06/06 06:51 AM As long as you replaced the F tune before it went in for service there is nothing that could effect your tune. Like you have already guessed it must be some "external" factor like a sensor failure or loose hose clamp. If your boost is the same as before you can safely eliminate the blow-off valve as being the problem. Link to comment Share on other sites More sharing options...
Iconic Bionic My engine bay is Bionic Donating Members 3,726 Member For: 18y 10m 3d Gender: Male Location: Freeways Posted 12/06/06 06:55 AM Share Posted 12/06/06 06:55 AM Great cars Ford make but there service efforts are real ordinary. Link to comment Share on other sites More sharing options...
igsta Member 371 Member For: 21y 3m 13d Gender: Male Location: Sydney Posted 12/06/06 06:58 AM Author Share Posted 12/06/06 06:58 AM I cant put the F tune back in because of larger squirters. I did put a 6psi tune in when I gave it to them for peace of mind. I put some tape over the socket where the edit plugs into saying do not flash and also I asked not to be flashed. My thoughts might be a faulty throttle position sensor as also sometimes when I put my foot down there is no response from my car for a second. Link to comment Share on other sites More sharing options...
igsta Member 371 Member For: 21y 3m 13d Gender: Male Location: Sydney Posted 12/06/06 07:01 AM Author Share Posted 12/06/06 07:01 AM Great cars Ford make but there service efforts are real ordinary.←Tell me about it. Every time I go there I say my seat belt does not retract it needs to be replaced, all they do is try and clean it and it does SFA to fix the problem. Link to comment Share on other sites More sharing options...
eat-xr6 Member 4 Member For: 18y 7m 15d Posted 12/06/06 07:05 AM Share Posted 12/06/06 07:05 AM (edited) yeah,they a bunch of ,they should all get f*cked Edited 12/06/06 07:09 AM by eat-xr6 Link to comment Share on other sites More sharing options...
saleen Big Gun Donating Members 4,170 Member For: 22y 3m 12d Gender: Male Location: NSW Posted 12/06/06 07:41 AM Share Posted 12/06/06 07:41 AM sounds liek they've done a flash update. time for a retune mate. Link to comment Share on other sites More sharing options...
igsta Member 371 Member For: 21y 3m 13d Gender: Male Location: Sydney Posted 12/06/06 09:32 AM Author Share Posted 12/06/06 09:32 AM Do Ford Flash using the same port we use our CAPA flash in. Link to comment Share on other sites More sharing options...
GlennAUII Former XT pilot Lifetime Members 4,791 Member For: 21y 5m 29d Gender: Male Location: The Womb Posted 12/06/06 09:45 AM Share Posted 12/06/06 09:45 AM Do Ford Flash using the same port we use our CAPA flash in.←yes.I'm not sure what they could have done. They usually only flash them if you complain about the car running badly. A 45,000km service consists of:-tyre pressures-brake inspection-change air filter-change oil filter-change oil-top up fluids incl p/s and brake fluid and washer bottle-check light bulbs Link to comment Share on other sites More sharing options...
tab Sucker Moderating Team 32,303 Member For: 20y 8m 28d Gender: Male Location: Brisbane Posted 12/06/06 10:47 AM Share Posted 12/06/06 10:47 AM sounds liek they've done a flash update. time for a retune mate.←But when he re-uploads wouldn't it just overwrite anything that they have done? And it would have been running pretty rich with the large injectors in any case Link to comment Share on other sites More sharing options...
