FSIX Member 566 Member For: 19y 7m 24d Posted 13/06/06 08:02 AM Share Posted 13/06/06 08:02 AM Be watchful when buying a Walbro or Bosch pumps there are imitations around make sure your pump is stamped with the maker and part number on the side of the pump.Ebay or mail order performance shops, is a place where you could end up with a imitation pump, some sellers are warning potential purchasers that there pumps are the genuine product. Link to comment https://www.fordxr6turbo.com/forum/topic/26115-walbro-pumps/page/3/#findComment-394117 Share on other sites More sharing options...
Adam Here since the start... Lifetime Members 10,282 Member For: 22y 1m 23d Gender: Male Location: Victoria Posted 15/07/06 01:15 AM Share Posted 15/07/06 01:15 AM I need to upgrade my fuel pump. I'm looking at the Walbro pumps as that seems to be what everyone is using as an in tank replacement.I've seen 2 models numbers that people are putting in there XR6T's:GSS-341GSS-342From what I can find they're both 255L/H.Does anyone know what the difference is between these 2 pumps?What's the going price for these and where's the best place to buy one?Thanks for you help. Link to comment https://www.fordxr6turbo.com/forum/topic/26115-walbro-pumps/page/3/#findComment-406855 Share on other sites More sharing options...
Romulus Donating Members 1,279 Member For: 20y 5m 13d Location: Perth Posted 15/07/06 01:26 AM Share Posted 15/07/06 01:26 AM (edited) Automotive Service Solutions (the old Petroject) sell an upgrade fuel pump kit for the XR6T / F6. It comes complete with the pump, small fuel line, and connector for the new fuel pump. Costs around $200 - $220 from memory.I've installed one of these with the new Walbro GSS-294 pump. Fits the factory cradle no problems. Also, the 294 pump is rated at 270l/hr, rather than 255l/hr like the older 341/342 pump.Doing a wiring modification to the car allows the pump to flow and extra 10-15% on top of the rated fuel flow in certain applications.Like BCL said, once you start making over 350rwkw you should consider fitting a swirl pot and a Bosch 044 pump to ensure consistant fuel delivery.Another modification to consider is bypassing the factory fuel pressure regulator and installing a rising rate adjustable reg, such as a Malpassi. Helps increase fuel pressure when running high boost levels. Edited 15/07/06 01:30 AM by M6 XR6T Link to comment https://www.fordxr6turbo.com/forum/topic/26115-walbro-pumps/page/3/#findComment-406863 Share on other sites More sharing options...
stedz101 Member 75 Member For: 20y 8m 13d Posted 15/07/06 02:12 AM Share Posted 15/07/06 02:12 AM I found using the standard covoluted fuel line in the caddy to be fine(just make sure that its clamped up nice and tight on the new pump) and used the std filter sock on the new gss 341 to work fine. Slight mod to the wiring required.If doing a ute, god help you getting the caddy out of the tank (very fiddly) but the sedans are quite easy. Link to comment https://www.fordxr6turbo.com/forum/topic/26115-walbro-pumps/page/3/#findComment-406868 Share on other sites More sharing options...
Robit28 Member 385 Member For: 19y 7m 18d Location: Brisbane Posted 15/07/06 12:36 PM Author Share Posted 15/07/06 12:36 PM Adam said: I need to upgrade my fuel pump. I'm looking at the Walbro pumps as that seems to be what everyone is using as an in tank replacement.I've seen 2 models numbers that people are putting in there XR6T's:GSS-341GSS-342From what I can find they're both 255L/H.Does anyone know what the difference is between these 2 pumps?What's the going price for these and where's the best place to buy one?Thanks for you help. :hiwelcome:←Not sure what the difference is but I installed a GSS342 the other week and got it in fine. It's nice and quiet and runs like a dream!I have read that the newer GSS-342 is higher pressure, same volume but at higher pressure.Rob. Link to comment https://www.fordxr6turbo.com/forum/topic/26115-walbro-pumps/page/3/#findComment-407054 Share on other sites More sharing options...
FSIX Member 566 Member For: 19y 7m 24d Posted 16/07/06 05:13 PM Share Posted 16/07/06 05:13 PM Adam said: I need to upgrade my fuel pump. I'm looking at the Walbro pumps as that seems to be what everyone is using as an in tank replacement.I've seen 2 models numbers that people are putting in there XR6T's:GSS-341GSS-342From what I can find they're both 255L/H.Does anyone know what the difference is between these 2 pumps?What's the going price for these and where's the best place to buy one?Just got another one last week from a local Ebay seller cost me $130.50 picked it up...He told me the GSS-341 will be discontinued soon and the GSS-342 is its replacement. Link to comment https://www.fordxr6turbo.com/forum/topic/26115-walbro-pumps/page/3/#findComment-407664 Share on other sites More sharing options...
Trough Lolly Member 4,349 Member For: 20y 9m 9d Gender: Male Location: Mildura Posted 17/07/06 01:25 AM Share Posted 17/07/06 01:25 AM HP-F installed a walbro in my ute, not sure on the model number but it does its job nicely. I can hear it whine from inside the cabin though Link to comment https://www.fordxr6turbo.com/forum/topic/26115-walbro-pumps/page/3/#findComment-407746 Share on other sites More sharing options...
rboksic Donating Members 514 Member For: 21y 1m 19d Posted 17/07/06 09:47 AM Share Posted 17/07/06 09:47 AM Robit28 said: Adam said: I need to upgrade my fuel pump. I'm looking at the Walbro pumps as that seems to be what everyone is using as an in tank replacement.I've seen 2 models numbers that people are putting in there XR6T's:GSS-341GSS-342From what I can find they're both 255L/H.Does anyone know what the difference is between these 2 pumps?What's the going price for these and where's the best place to buy one?Thanks for you help. ←Not sure what the difference is but I installed a GSS342 the other week and got it in fine. It's nice and quiet and runs like a dream!I have read that the newer GSS-342 is higher pressure, same volume but at higher pressure.Rob.←The inlet and outlet are directly opsite each other on the 342on the 341 outlet is at 12oclock inlet at 6 oclock Link to comment https://www.fordxr6turbo.com/forum/topic/26115-walbro-pumps/page/3/#findComment-407995 Share on other sites More sharing options...
Adam Here since the start... Lifetime Members 10,282 Member For: 22y 1m 23d Gender: Male Location: Victoria Posted 17/07/06 09:49 AM Share Posted 17/07/06 09:49 AM Thanks for all the info guys! rboksic, does one of those match the inlet and outlets of the stock pump? If one does I'm guessing it makes it a lot easier to install. Link to comment https://www.fordxr6turbo.com/forum/topic/26115-walbro-pumps/page/3/#findComment-407997 Share on other sites More sharing options...
DAVO61 Member 70 Member For: 20y 7m 1d Posted 19/07/06 11:13 AM Share Posted 19/07/06 11:13 AM hi can anyone tell me what rwkw you need to upgrade fuel pump as I have 242 now but am looking at doing injectors , 3.5" dump metal cat and a retune. will I need fuel pump as well. Link to comment https://www.fordxr6turbo.com/forum/topic/26115-walbro-pumps/page/3/#findComment-409132 Share on other sites More sharing options...
