Flash Tuner - Are Generic Tunes Different
Falchoon
yeh I realise that but the point in making is that if you have a heavily modified T, why would you want the latest update. But im sure if you have flashed your box back to stock you could then upload the new ford flash map on to the box as the box would not be VIN locked anymore once you load the stock map back into the car. Though im not sure if this will effect any custom maps on the box.
  • Member For: 20y 11m 10d
It's Vin locked the first time you connect it to your car and run the flash tuner.
  • Team Grandpa
  • Member For: 18y 11m 10d
M6, Simon, Steve, Wog.....etc
Questions I have but are still not clear.......sorry to be a PITA
You buy a CAPA unit
You get a custom tune
You go back to Ford so you change back to stock so not to ruin your tunes.
Ford Flash an update to your original stock tune
How is this new stock tune from Ford put into you CAPA box?
Do you just overwrite the old one? Or will the box need to be reset hence reseting your 3 higher boost tunes?
is the box not vin locked once you load the stock map back into it?
  • Member For: 19y 6m 25d
Even if you flash it back to stock the VIN is still locked. VIN is recorded on first connection to a "clean" box. (Box with a blank or free VIN field)
  • Member For: 20y 3m 5d
You buy a CAPA unit
The new flash overwrites the old factory tune in the tune box. You still retain your 1,2 and 3 custom tunes.
ok so you return your car back to stock tune, the box is still vin locked. how do you change the box over to work on another car then if you sell it ect?
That way you can not share 1 box will all your mate's,
why do you think it was looked for in the first place?
You go back to your tuner and he resets the box.
ok I get it now, the tuner has to reset the box, so if you were buying a used item for instance the car would have had to be returned to stock and box be reset by the tuner before you can use it.
Yes that's right.
