Dillz Three pedals are better then two.. Donating Members 15,637 Member For: 18y 19d Gender: Male Location: Melbourne Posted 29/11/11 10:30 PM Share Posted 29/11/11 10:30 PM If it's fluttering (tu tu tu) that means the bov isn't working properly. I.e it's not venting enough excess air. Link to comment https://www.fordxr6turbo.com/forum/topic/25971-turbosmart-blow-off-valves-thread/page/22/#findComment-1164291 Share on other sites More sharing options...
Meadey82 Member 3 Member For: 13y 7m 12d Posted 29/11/11 11:49 PM Share Posted 29/11/11 11:49 PM So being a dual port that would mean its also not recording enough air either yes?What should I change/adjust to eliminate this? I change to soft setting with 1 shim and it does the same. Given this was described as a simple change over blow off valve to replace the factory bosch. Is it possible the trumpet and recirc air pipes were put on incorrect spots from the factory? As I simply removed it from the box and fitted it. Link to comment https://www.fordxr6turbo.com/forum/topic/25971-turbosmart-blow-off-valves-thread/page/22/#findComment-1164305 Share on other sites More sharing options...
Meadey82 Member 3 Member For: 13y 7m 12d Posted 29/11/11 11:50 PM Share Posted 29/11/11 11:50 PM Recirculating, not recording. Damn iPhone spell correct. Link to comment https://www.fordxr6turbo.com/forum/topic/25971-turbosmart-blow-off-valves-thread/page/22/#findComment-1164306 Share on other sites More sharing options...
Dillz Three pedals are better then two.. Donating Members 15,637 Member For: 18y 19d Gender: Male Location: Melbourne Posted 30/11/11 01:25 AM Share Posted 30/11/11 01:25 AM Is it on properly? Have it as tight as possible then keep loosening it till it sounds how you want it. Link to comment https://www.fordxr6turbo.com/forum/topic/25971-turbosmart-blow-off-valves-thread/page/22/#findComment-1164327 Share on other sites More sharing options...
BlueDevil81 Member 10 Member For: 13y 11m 29d Gender: Male Location: Townsville Posted 11/05/12 08:28 AM Share Posted 11/05/12 08:28 AM I purchased my Turbo smart BOV dual port from Intunemotorsport.com.au which you will find under the products section( they do sell some useful products). Its a direct replacement for the factory BOV. It have installed to atmos. It can be changed to plumb back by screwing in a small plate with an allen key. Its much louder than the factory one and its quite funny how much people turn around when the turbo spools up and the BOV vents. I guess it does that when its on 18 psi lol. I am careful around cops not to put the foot down because of the attention Link to comment https://www.fordxr6turbo.com/forum/topic/25971-turbosmart-blow-off-valves-thread/page/22/#findComment-1235495 Share on other sites More sharing options...
bossmang FREAKY Donating Members 12,440 Member For: 15y 5m 20d Gender: Male Location: Melbourne Posted 11/05/12 08:46 AM Share Posted 11/05/12 08:46 AM yer I found that the vent on those went too long. like 5 seconds. I didnt like it. and I put in the strongest spring in it and all the washes. it still vented too long. Link to comment https://www.fordxr6turbo.com/forum/topic/25971-turbosmart-blow-off-valves-thread/page/22/#findComment-1235519 Share on other sites More sharing options...
Poelwyk Member 99 Member For: 13y 9m 23d Gender: Male Location: Werribee,Melbourne, Australia Posted 12/05/12 02:21 AM Share Posted 12/05/12 02:21 AM guys I brought a turbosmart Bov and the thing dont fit the inlet and outlets are way too big what can I do ... sould I just take the thing back or what I runn a Plazman under bat intake and a Prosseswest Coller kit with cold shide pipeing I think the Connections are 25MM Link to comment https://www.fordxr6turbo.com/forum/topic/25971-turbosmart-blow-off-valves-thread/page/22/#findComment-1235905 Share on other sites More sharing options...
Poelwyk Member 99 Member For: 13y 9m 23d Gender: Male Location: Werribee,Melbourne, Australia Posted 12/05/12 02:40 AM Share Posted 12/05/12 02:40 AM sorry Rapid systems cooler Link to comment https://www.fordxr6turbo.com/forum/topic/25971-turbosmart-blow-off-valves-thread/page/22/#findComment-1235910 Share on other sites More sharing options...
stevanford Member 268 Member For: 13y 4m 13d Posted 09/09/12 03:57 AM Share Posted 09/09/12 03:57 AM Anybody use a Turbosmart Kompact plumb back Bov ? Are they worth the money ? Link to comment https://www.fordxr6turbo.com/forum/topic/25971-turbosmart-blow-off-valves-thread/page/22/#findComment-1292142 Share on other sites More sharing options...
slygary Member 31 Member For: 12y 5m 1d Gender: Male Location: Geelong Posted 17/01/13 05:31 AM Share Posted 17/01/13 05:31 AM I installed mine today. I had to unscrew and swap over the pipe and trumpet for it to fit 100%. Mine came with a little cd to put in the computer and if you read the install and adjust insructions on how to set it up you cant go wrong. I had to install 4 shims for it to have good movement of adjustment. Link to comment https://www.fordxr6turbo.com/forum/topic/25971-turbosmart-blow-off-valves-thread/page/22/#findComment-1350689 Share on other sites More sharing options...
