Chich Damn You's A Sexy Chich Member 3,843 Member For: 17y 3m 29d Gender: Male Location: Your House Posted 26/08/08 10:02 AM Share Posted 26/08/08 10:02 AM well, tighten it up a turn or 2, and keep doing that till the idle problem goes away, that's what I did with mine works fine now Link to comment https://www.fordxr6turbo.com/forum/topic/25971-turbosmart-blow-off-valves-thread/page/16/#findComment-723717 Share on other sites More sharing options...
xr6tute Member 50 Member For: 18y 6m 5d Gender: Male Posted 05/11/08 10:44 AM Share Posted 05/11/08 10:44 AM Hi boys,I got advice off a member on here about BOV's, which was much appreciated. He recomended a 38mm dual port. So I went into repco today to buy one, and they had the 32mm version on special for $160. Compared to the $500 they wanted for the 38mm, that was pretty cheap. I ended up buying the 32mm. I just wanted to konw if it will be suitable?? I am currently running 8psi, but that will be going up in the future...may be 12-15 psi.What to you guys think???Thanks. Link to comment https://www.fordxr6turbo.com/forum/topic/25971-turbosmart-blow-off-valves-thread/page/16/#findComment-762849 Share on other sites More sharing options...
xr6tute Member 50 Member For: 18y 6m 5d Gender: Male Posted 07/11/08 10:22 AM Share Posted 07/11/08 10:22 AM Anyone? Link to comment https://www.fordxr6turbo.com/forum/topic/25971-turbosmart-blow-off-valves-thread/page/16/#findComment-763905 Share on other sites More sharing options...
PHANTMXR6 It's not a MKI! Member 1,742 Member For: 16y 11m 26d Gender: Male Location: Earth Posted 07/11/08 11:52 AM Share Posted 07/11/08 11:52 AM Irrelevent now. You already bought it.But, it should suffice.My FG runs up to 12-13psi standard and the factory 25mm BOV is fine. Link to comment https://www.fordxr6turbo.com/forum/topic/25971-turbosmart-blow-off-valves-thread/page/16/#findComment-763932 Share on other sites More sharing options...
xr6tute Member 50 Member For: 18y 6m 5d Gender: Male Posted 08/11/08 04:21 AM Share Posted 08/11/08 04:21 AM PHANTMXR6 said: Irrelevent now. You already bought it.But, it should suffice.My FG runs up to 12-13psi standard and the factory 25mm BOV is fine.Not really seeing that I have the option of returning it , as long as I have not used.Thanks anyway. Link to comment https://www.fordxr6turbo.com/forum/topic/25971-turbosmart-blow-off-valves-thread/page/16/#findComment-764151 Share on other sites More sharing options...
Skooting_turbo New Member 1 Member For: 16y 7m 10d Gender: Male Location: Canberra Posted 09/12/08 05:20 AM Share Posted 09/12/08 05:20 AM Hey GuysJust thought Id chuck my opinion in, cause alot of people are talking about taking off there BOV when there running around 15 psi .I was told and have seen a few cars bend throttle butterflys when this is done just be careful. If you start pulling more boost out of it and u dont have a BOV you can damage the compressor. To much air is being forced through and somthings gotta give watch your seals also make sure there tight. Link to comment https://www.fordxr6turbo.com/forum/topic/25971-turbosmart-blow-off-valves-thread/page/16/#findComment-783316 Share on other sites More sharing options...
Bullyz_XR6T_2009 Member 3 Member For: 16y 4m 12d Gender: Male Location: Traralgon Posted 02/02/09 06:13 AM Share Posted 02/02/09 06:13 AM hey ppl I brought a BA XR6T and im thinking of putting a turbosmart kompact series (supersonic) on do they give good noise im after wank factor till I save money to upgrade lol Link to comment https://www.fordxr6turbo.com/forum/topic/25971-turbosmart-blow-off-valves-thread/page/16/#findComment-815123 Share on other sites More sharing options...
PHANTMXR6 It's not a MKI! Member 1,742 Member For: 16y 11m 26d Gender: Male Location: Earth Posted 02/02/09 10:42 AM Share Posted 02/02/09 10:42 AM If it's wank factor you're after then wank factor yee shall receive. Link to comment https://www.fordxr6turbo.com/forum/topic/25971-turbosmart-blow-off-valves-thread/page/16/#findComment-815457 Share on other sites More sharing options...
blue_xr6 Member 40 Member For: 16y 8m 12d Posted 14/02/09 02:00 AM Share Posted 14/02/09 02:00 AM Just have a quick question regards to the turbosmart kompact bov. As far as I know the dual port bov allows you to adjust the pressure venting to be either plumb back or supersonic. Just wondering for the dual port, if you adjust the all the venting to atmosphere, does it sound as loud as the supersonic one?Also, I heard that both the dual port and supersonic bov are directly fit to the standard BOV, but the dual port is easier to install as you don't have to block the plumb back hose from the factory unit. Is it correct?Thanks Link to comment https://www.fordxr6turbo.com/forum/topic/25971-turbosmart-blow-off-valves-thread/page/16/#findComment-822865 Share on other sites More sharing options...
MRDOSE Member 1,195 Member For: 17y 5m 16d Gender: Male Location: Sydney Posted 14/02/09 04:15 AM Share Posted 14/02/09 04:15 AM when I was crusing with onboost I THINK I may have heard his kompact vent... but I might have farted Link to comment https://www.fordxr6turbo.com/forum/topic/25971-turbosmart-blow-off-valves-thread/page/16/#findComment-822962 Share on other sites More sharing options...
