hulk xr6t Member 160 Member For: 17y 7m 27d Posted 05/05/08 02:21 AM Share Posted 05/05/08 02:21 AM The turbosmart guy also reckons the stock bov is worth $30 and leaks boost all over the place?Do you reckon they sit there all day and discuss BOV's? They must be fully sick.. Link to comment https://www.fordxr6turbo.com/forum/topic/25971-turbosmart-blow-off-valves-thread/page/12/#findComment-670938 Share on other sites More sharing options...
XF Falcon <put funny sh*t here> Member 3,365 Member For: 18y 7m 4d Gender: Male Location: Perth, NOR Posted 05/05/08 02:23 AM Share Posted 05/05/08 02:23 AM I had my BOV spring set too soft and I think that was the cause of my boost leak sound my car was making. Simon made it firmer and it seemed to fix the problem. It just flutters a lot more now that its a firmer spring setting. Link to comment https://www.fordxr6turbo.com/forum/topic/25971-turbosmart-blow-off-valves-thread/page/12/#findComment-670942 Share on other sites More sharing options...
skunk Member 236 Member For: 17y 7m 17d Gender: Male Location: melb Posted 05/05/08 02:49 AM Share Posted 05/05/08 02:49 AM im with XF on this one. I had mine set to the hardest n it felt better by way of response as oppsoed to being set on the lose setting.iv since put the stock BOV back on now though..the PSSHHH every 2 secs got on my nervs lol. might take the BOV off completly n see how it goes. Link to comment https://www.fordxr6turbo.com/forum/topic/25971-turbosmart-blow-off-valves-thread/page/12/#findComment-670960 Share on other sites More sharing options...
senna_T Forged Member Lifetime Members 15,818 Member For: 18y 4m 5d Gender: Male Location: SW Sydney Posted 05/05/08 02:57 AM Share Posted 05/05/08 02:57 AM hulk xr6t said: Do you reckon they sit there all day and discuss BOV's? They must be fully sick..It is their job, I guess if they didn't know anything about it they wouldn't be the biggest turbo accessory manufacturer in the world Link to comment https://www.fordxr6turbo.com/forum/topic/25971-turbosmart-blow-off-valves-thread/page/12/#findComment-670965 Share on other sites More sharing options...
hulk xr6t Member 160 Member For: 17y 7m 27d Posted 05/05/08 05:32 AM Share Posted 05/05/08 05:32 AM (edited) XF Falcon said: I had my BOV spring set too soft and I think that was the cause of my boost leak sound my car was making. Simon made it firmer and it seemed to fix the problem. It just flutters a lot more now that its a firmer spring setting.The guy at Turbosmart said no matter if its on soft or hard it wont leak boost. He said all it will do is close the shaft quicker or slower when blowing off dependant upon soft or hard... ie letting more or less air being vented...He said it has nothing to do with boost leaks....???? What do we think??Also Do the stock bovs leak or it that just a Turbosmart myth... Edited 05/05/08 05:32 AM by hulk xr6t Link to comment https://www.fordxr6turbo.com/forum/topic/25971-turbosmart-blow-off-valves-thread/page/12/#findComment-671015 Share on other sites More sharing options...
Dagabond Bored Member Administrator 35,722 Member For: 22y 6m 29d Gender: Male Location: Dé·jà vu Posted 05/05/08 05:45 AM Share Posted 05/05/08 05:45 AM I think he's right....Kind of .....as its a controlled boost leak when it comes down to it...... Link to comment https://www.fordxr6turbo.com/forum/topic/25971-turbosmart-blow-off-valves-thread/page/12/#findComment-671026 Share on other sites More sharing options...
XF Falcon <put funny sh*t here> Member 3,365 Member For: 18y 7m 4d Gender: Male Location: Perth, NOR Posted 05/05/08 05:56 AM Share Posted 05/05/08 05:56 AM If the spring is set too soft, and your making heaps of boost, sure there is the vacuum line on the BOV but im sure the boost will lift up the valve a little bit and let a bit of boost out, yeah? or not Link to comment https://www.fordxr6turbo.com/forum/topic/25971-turbosmart-blow-off-valves-thread/page/12/#findComment-671031 Share on other sites More sharing options...
senna_T Forged Member Lifetime Members 15,818 Member For: 18y 4m 5d Gender: Male Location: SW Sydney Posted 05/05/08 06:08 AM Share Posted 05/05/08 06:08 AM you ahve to remember the stock BOV is only a 25mm too, once the boost starts to rise a larger BOV is a better idea so it is more efficient, a 38mm would be good for anything over 10psi IMO Link to comment https://www.fordxr6turbo.com/forum/topic/25971-turbosmart-blow-off-valves-thread/page/12/#findComment-671044 Share on other sites More sharing options...
hypnodoc It's All In Your Mind Gold Donating Members 2,198 Member For: 21y 7m 14d Gender: Male Location: Melbourne Posted 05/05/08 09:07 AM Share Posted 05/05/08 09:07 AM (edited) Finally bought something I could easily fit myself. I have put in the replacement TurboSmart Blowoff valve. It fitted in no hassels at all. Once fitted I turned it back half a turn form full tension. Is this correct or is there something more scientific I should do ?Cheers Edited 05/05/08 09:07 AM by hypnodoc Link to comment https://www.fordxr6turbo.com/forum/topic/25971-turbosmart-blow-off-valves-thread/page/12/#findComment-671157 Share on other sites More sharing options...
mic Donating Members 1,725 Member For: 17y 4m 25d Gender: Male Posted 05/05/08 09:36 AM Share Posted 05/05/08 09:36 AM There should be an adjustment mark that you cannot exceed and screw past. Anywhere between there and full shut is fine. Just depends how easily you would like it to expel air. Link to comment https://www.fordxr6turbo.com/forum/topic/25971-turbosmart-blow-off-valves-thread/page/12/#findComment-671173 Share on other sites More sharing options...
