  • Member For: 19y 10m 21d
  SAMSXR6T said:
Hi  Cowiesxr6t  my turbo also is on its last legs... could you tell me if your turbo is being rebuilt or replaced...
SamSXR6T
The turbo is getting a full rebuilt. Wife was surpose to pick it up today but will be tomorrow. Will let you guys know what the outcome was.
Cheers
Paul
  • Replies 34
  built2redline said:
how often did you service the car?
car has been serviced at all the right intervals. Ford has done the last two.....
Paul
  • Member For: 20y 13d
just asking because I allways thought that 15000ks between services was a bit much for a turbo car
it would be interesting to see if a car serviced every 5000ks would have had the same problem
  • Member For: 20y 3m 8d
Spoke to a tuner who was installing a new actuator for me... he had to pull the turbo out and noticed all the fines on the turbo are all bent backwards... could be a number of thing that could have caused this to happen... I also have the extended warranty and had the gearbox replaced 3 months ago and I was reading your thread and thought that I might try to get a replacement turbo under warranty but it might be difficult going by my history with the box... I could not be bothered to strip the car to stock standard, so ill bay the $3000 to supply and fit...
  • Member For: 18y 11m 18d
G'day Paul,
So who is the Mackay performance shop you refer to? Sounds like a decent recommendation to me.
Some of us also have extended warranties that we're not too worried about invalidating :) Anywho I'm glad things worked out OK.
  • Member For: 20y 3m 17d
The extended warranty sounds interesting.
Is this through the Ford dealer, or where can I get one. MY car is under lease but I intend to keep it fo 3 years more than the warranty. I should be able to buy the ext warranty through the vehicle lease. Saves a few dollars.
Extended warranty is fantastic if you haven’t got major mods done to your car... Ford would also not be in a position to replace certain parts under warranty if they feel that mods that you have added to your car caused the damage... :blush:
Hi All
Have the car back now and running like new again. Big thanks to Jam Performance who done all the work.
It looks like there was a there was no oil geeting to the turbo. The oil line that runs to the turbo was built up with carbon deposit. They cut 9" of the line and was clogged up with deposit not letting the oil to the turbo.
Not sure how long it had been that way as I said in the first post there was NO warning that the turbo was on its way out. As I said it sat there for a couple of days in the shed and then kicked it over???
So all good now.
Paul
