CSV_LS1 Member 303 Member For: 21y 1m 28d Gender: Male Posted 28/05/06 01:52 PM Share Posted 28/05/06 01:52 PM Can a turbo tune be flashed in if the box originally came with V8 tunes? Link to comment https://www.fordxr6turbo.com/forum/topic/25688-using-flash-tuner-with-v8-tune-on-turbo/ Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,332 Member For: 19y 7m 7d Gender: Male Location: Perth Posted 28/05/06 01:57 PM Share Posted 28/05/06 01:57 PM Yes. Get the box reset and then Turbo tunes put on it and your away..most tuners can do this.. Link to comment https://www.fordxr6turbo.com/forum/topic/25688-using-flash-tuner-with-v8-tune-on-turbo/#findComment-387482 Share on other sites More sharing options...
CSV_LS1 Member 303 Member For: 21y 1m 28d Gender: Male Posted 28/05/06 02:00 PM Author Share Posted 28/05/06 02:00 PM Great. Thanks Link to comment https://www.fordxr6turbo.com/forum/topic/25688-using-flash-tuner-with-v8-tune-on-turbo/#findComment-387484 Share on other sites More sharing options...
gogo Member of team Kittens Member 609 Member For: 21y 2m 7d Location: Melbourne Posted 28/05/06 11:07 PM Share Posted 28/05/06 11:07 PM If the flasher has been used, it might have to go back to Capa to be reset - if it has not been vin locked then your tuner will be able to input the correct files for your car - but either way there SHOULDN'T be problems using the unit itself (not sure if CAPA charge to reset - perhaps give them a call to confirm details and any costs).Cheers, Ben. Link to comment https://www.fordxr6turbo.com/forum/topic/25688-using-flash-tuner-with-v8-tune-on-turbo/#findComment-387571 Share on other sites More sharing options...
qwigybo Member 288 Member For: 18y 11m 26d Location: bendigo home of SFA Posted 30/05/06 07:14 PM Share Posted 30/05/06 07:14 PM if a box hasn't been VIn locked are you able to have a tune for V8 and one for Turbo on the same box ? Link to comment https://www.fordxr6turbo.com/forum/topic/25688-using-flash-tuner-with-v8-tune-on-turbo/#findComment-388550 Share on other sites More sharing options...
macka'sxr6t Member 1,480 Member For: 20y 11m 2d Location: Mildura Posted 01/06/06 11:18 PM Share Posted 01/06/06 11:18 PM qwigybo said: if a box hasn't been VIn locked are you able to have a tune for V8 and one for Turbo on the same box ?←The way I understand it, yes it's possible it can hold 3 different tunes. The problem will be when you go to use it.Before you can down load the tunes in the box you must upload the tune that's been loaded from the factory. This is when the box becomes vin locked to that vehicle. To be able to use the other tune you would have to have then have the box reset. I would assume that that would mean clearing the original factory upload. The process would be the same when you use it on the other car which means that it would then be vin locked to that car.Remember you can only have it cleared 5 times before it must be sent back to SCT.I suppose it would be a cheap way of custom tuning 2 cars, provided you intended only use those tunes all the time.Could get very messy though if Ford decide to reflash both cars with an update thoughHope that makes some sense. If I'm wrong someone will correct itmacka Link to comment https://www.fordxr6turbo.com/forum/topic/25688-using-flash-tuner-with-v8-tune-on-turbo/#findComment-389514 Share on other sites More sharing options...
RAPHOON Donating Members 1,776 Member For: 21y 10m 3d Posted 01/06/06 11:40 PM Share Posted 01/06/06 11:40 PM If it has been used once, it is locked to the VIN of the car it has been used on, and it's this car's factory tune stored in the F slot.The tuner who loads in the turbo tunes will be able to clear the F slot for you at the same time as he loads in the new tunes into slots 1,2 & 3. Once you use it on your car, it will first load your factory tune into slot F. The box will then be locked into your car. Link to comment https://www.fordxr6turbo.com/forum/topic/25688-using-flash-tuner-with-v8-tune-on-turbo/#findComment-389526 Share on other sites More sharing options...
cobrav8 Member 1,969 Member For: 20y 1m 6d Gender: Male Location: New Zealand Posted 02/06/06 12:20 AM Share Posted 02/06/06 12:20 AM You will not be able to juggle it so that two cars are modded.One of the cars has to go back to standard - then the unit unlocked - before the next car ends up modded. Link to comment https://www.fordxr6turbo.com/forum/topic/25688-using-flash-tuner-with-v8-tune-on-turbo/#findComment-389536 Share on other sites More sharing options...
qwigybo Member 288 Member For: 18y 11m 26d Location: bendigo home of SFA Posted 02/06/06 05:35 PM Share Posted 02/06/06 05:35 PM ah well was worth a try the bro in-law has one for his xr8 cos it's on gas, so I though hey, maybe I can get out of buying one haha Link to comment https://www.fordxr6turbo.com/forum/topic/25688-using-flash-tuner-with-v8-tune-on-turbo/#findComment-389867 Share on other sites More sharing options...
RAPHOON Donating Members 1,776 Member For: 21y 10m 3d Posted 04/06/06 10:24 PM Share Posted 04/06/06 10:24 PM Nice idea, but no. Link to comment https://www.fordxr6turbo.com/forum/topic/25688-using-flash-tuner-with-v8-tune-on-turbo/#findComment-390552 Share on other sites More sharing options...
