macka'sxr6t Member 1,480 Member For: 20y 10m 7d Location: Mildura Posted 24/06/06 12:45 PM Share Posted 24/06/06 12:45 PM man out on the road the improvement is crazy boost comes on really well and feels heaps more powerful I got a torque reading aswell I just dunno how to read it properly←Mate you should be able to work out you torque at any of the plot points on your dyno graph. Just use this formulae. KW x 9549 / rpm eg 200 x 9549 / 4000 rpm. I don't no what the formulae would be for HP readings. But you maybe able to use a converter from HP to KW to give you a rough idea if your dyno gragh is'nt in KWI'm mainly interested in the torque readings as I have been told that they should be higher than a normal xr6turbo because of the higher compression ratio, but the actual KW maybe lower because you cannot run tha boost as highmacka Link to comment Share on other sites More sharing options...
macka'sxr6t Member 1,480 Member For: 20y 10m 7d Location: Mildura Posted 24/06/06 12:46 PM Share Posted 24/06/06 12:46 PM pic, might not have uploaded properly can you post again macka Link to comment Share on other sites More sharing options...
51KBA 2005 BA MK11 turbo Member 140 Member For: 19y 2m 29d Gender: Male Location: sunshine coast Posted 24/06/06 12:52 PM Author Share Posted 24/06/06 12:52 PM heres some hope they helpvip_day_2.bmp Link to comment Share on other sites More sharing options...
51KBA 2005 BA MK11 turbo Member 140 Member For: 19y 2m 29d Gender: Male Location: sunshine coast Posted 24/06/06 12:57 PM Author Share Posted 24/06/06 12:57 PM that dyno sheet I posted up b4 does have a lb reading on it Link to comment Share on other sites More sharing options...
macka'sxr6t Member 1,480 Member For: 20y 10m 7d Location: Mildura Posted 24/06/06 01:02 PM Share Posted 24/06/06 01:02 PM Cooler looks good from the front what type is it? The factory plastic and rubber inake is holding up OK. Have you any plans to alter it?I would like to see the pod filter tucked away out of sight under the battery at some stage. Just to tidy up the engine bay. But that's just my OP pls don't take offence macka Link to comment Share on other sites More sharing options...
51KBA 2005 BA MK11 turbo Member 140 Member For: 19y 2m 29d Gender: Male Location: sunshine coast Posted 24/06/06 01:07 PM Author Share Posted 24/06/06 01:07 PM none taken mate I like the way yours is done I am looking at relocating the battery at some stage so that's where the pod will go im looking at doing the same intake pipe as yours when I go up in boost the ic is a hybrid copy from ebay Link to comment Share on other sites More sharing options...
macka'sxr6t Member 1,480 Member For: 20y 10m 7d Location: Mildura Posted 24/06/06 01:13 PM Share Posted 24/06/06 01:13 PM Mate, just found a hp to kw converter. You 5 psi 249 hp dyno run equalls a smidge over 186 rwkw. You 269 hp equalls a little over 200 rwkw. this should give something to use to work out your torque using the formulae I gave you.Excellent results IMOP. They equal some of the strongest readings I've heard about. Is your car a manual or auto?macka Link to comment Share on other sites More sharing options...
51KBA 2005 BA MK11 turbo Member 140 Member For: 19y 2m 29d Gender: Male Location: sunshine coast Posted 24/06/06 01:16 PM Author Share Posted 24/06/06 01:16 PM its manual mate so yeah there has been no traction in 1st lol Link to comment Share on other sites More sharing options...
macka'sxr6t Member 1,480 Member For: 20y 10m 7d Location: Mildura Posted 24/06/06 01:27 PM Share Posted 24/06/06 01:27 PM Mate just done some basic calcs from your graph. @ 2500 rpm you have approx 490 nm of torque It would be good to see the look on the Expensive Daewoo boy's faces when they've been blown away by an N/A xr6 macka Link to comment Share on other sites More sharing options...
turbotrana Member 2,586 Member For: 22y 4d Gender: Male Posted 24/06/06 01:51 PM Share Posted 24/06/06 01:51 PM what are you doing (if anything) about getting the car legally registered and insured as a Turbo? Link to comment Share on other sites More sharing options...
