Monzie Member 8 Member For: 19y 4m 26d Posted 20/05/06 04:10 PM Share Posted 20/05/06 04:10 PM Hey guys...I just got my XR and I got a set of pioneer comp subs and wanna stick em in my bootI got the premium sound but its just not doin it for me. so I spoke to the ford machanics and they reckon that I can't replace the pissy 150watt factory amp, as it is wired in with the ECU...They said that seeing as its a 120 watt sound system I can only make it louder, the actual sound quality wont be effected. Has anyone customised thier sound system.Because the ford guys said to install the woofers anyway, and that hey will be able to run at max bass with no problem (derr)so bassically does anyone know any different? or weather infact I can replace the factor amp with a good one?thanks. Link to comment https://www.fordxr6turbo.com/forum/topic/25503-replacing-with-custom-subs/ Share on other sites More sharing options...
Panda Member 225 Member For: 21y 2m 23d Gender: Male Location: Gladstone, QLD Posted 21/05/06 08:45 AM Share Posted 21/05/06 08:45 AM Couple of different options.If you have an amp with high level inputs, you can run the factory subwoofer speaker leads to the amp and drive the aftermarket subs with it.If your amp doesn't have high level inputs, you can run your factory subwoofer speaker leads into a line level converters then to your aftermarket amp, then to your aftermarket sub.If you wanted to go the whole hog, ASL Logistics can install an RCA output on the rear of your ICC so you can output directly to an aftermarket amp which is driving your subs.Panda Link to comment https://www.fordxr6turbo.com/forum/topic/25503-replacing-with-custom-subs/#findComment-384331 Share on other sites More sharing options...
INPURSUIT Fastest Taxi In Melbourne Donating Members 701 Member For: 19y 3m 26d Gender: Male Location: Melbourne Posted 21/05/06 11:26 AM Share Posted 21/05/06 11:26 AM http://www.asllogistics.com/ford_upgrades.htmltry them. with this you are able to add an amplifier to your existing stereo through low level outputs or something.im thinking of upgrading my stereo aswell and this looks like the best option Link to comment https://www.fordxr6turbo.com/forum/topic/25503-replacing-with-custom-subs/#findComment-384454 Share on other sites More sharing options...
Monzie Member 8 Member For: 19y 4m 26d Posted 21/05/06 03:00 PM Author Share Posted 21/05/06 03:00 PM Awesome... Thanks alot Panda and XR6BoyHelped heaps I'll let u know how it goes..Monzie Link to comment https://www.fordxr6turbo.com/forum/topic/25503-replacing-with-custom-subs/#findComment-384532 Share on other sites More sharing options...
RAP1D Member Donating Members 3,739 Member For: 19y 1m 16d Gender: Male Location: Sydney NSW Posted 22/05/06 07:18 AM Share Posted 22/05/06 07:18 AM I just added a 12in JL sub to mine... just take the wires off the orig sub and wire them straight to the new sub.The JL sub made a huge difference to the systems sound, bass is now typical JL sounding bass, obviously not hitting huge dB's, but loud, high quality bass. Link to comment https://www.fordxr6turbo.com/forum/topic/25503-replacing-with-custom-subs/#findComment-384743 Share on other sites More sharing options...
joostenjohn60 Member 16 Member For: 19y 4m 16d Posted 22/05/06 09:36 AM Share Posted 22/05/06 09:36 AM I am adding a pioneer 12" sub and for the moment I will use the factory amp and make an adaptor plate to fire the sub through the existing factory mounting position . The 12 will move a lot more air than the 8 or 10 that is there now so will be louder hopefully enough if not there are some 15's in the shed. Link to comment https://www.fordxr6turbo.com/forum/topic/25503-replacing-with-custom-subs/#findComment-384822 Share on other sites More sharing options...
