TUR80_6 Member 13 Member For: 18y 8m 25d Posted 24/05/06 12:03 AM Share Posted 24/05/06 12:03 AM Mark and Jo did ny bf gt front bar and it looks hot as. I also put on a djr bobtail. Thanks guys your gear it unreal Link to comment Share on other sites More sharing options...
XR6IXT Donating Members 662 Member For: 19y 5m 12d Gender: Male Location: Adelaide Posted 25/05/06 09:19 AM Share Posted 25/05/06 09:19 AM TURBO 6 do you have any photos of your car??? Link to comment Share on other sites More sharing options...
Ninka Donating Members 1,850 Member For: 22y 1m 10d Gender: Male Location: Perth, WA Posted 25/05/06 12:12 PM Share Posted 25/05/06 12:12 PM Only real problem you will find is getting them colour matched properly, especially with the lighter colours. The ford paint barely covers the undercoat and when you get the kit sprayed it will be slightly different, and there was also a problem with static from the fibreglass causing the paint to do funny things when sprayed on.←I have the full AWC BA GT kit on my car, and the kit fits quite well.Front bar is particularly easy to fit, rear bar require original mounting brackets to be moved for std. bar (require some large blind rivets).Comments made by Steve above are valid points, and little pinholes may also require a bit more prep work than usual.Biggest issue to fit can be the side skirts, as these can twist and shorten or lengthen during the curing process, but once on the car, all is sweet. Link to comment Share on other sites More sharing options...
