Auto Problem
mrturboman
  • Member For: 20y 5m 18d
Hi, I've got BA Fslcon xr6 turbo aps phase 2 kitted. when goin to 2nd to 3rd it flares under load. I replaced the transmission st thru ford yesterday still same problem , but they fitted original torque converter back in, can that cause the problem, can any one help.thanks
  • Member For: 19y 13d
did they do the warranty work knowing that you are running aps gear, strange anyway recomend getting a rebuilt auto. I have aps phase II running 270rwk auto started flaring 2nd to third,, took easy for a while then brother drove car wollar!!! woudnt change 2nd to 3rd at all so had it rebuilt by tony at yarra vally automatics, couldnt be happier hasnt missed a beat shaved 1/2 sec off 1/4 mile time.
Shop around now though try kewish automatics in dandy, or preston automatics as well and get the rebuilt u wont regret it.
  • Site protagonist
  • Member For: 21y 9m 3d
If you went in and it was slipping and came out and it still slipping they didn't replave the auto. I also believe that ION (company that makes the auto) has to ok every auto warrenty claim, If you have APSII they wouldn;t have done so.
Your problam is the band has gone. This will ned to be replaced and whilst doing this you may aswell look at the rest of the box too. I'd give Dave from Kewish a ring and book it in.
Geea. :spoton:
  • Member For: 21y 11m 6d
Geea. :spoton:
yeh they change it, I knew a guy at ford, I checked the box its brand new.
Geea. :spoton:
could be the PCM or torque converter
  • Team Grandpa Qualified
  • Member For: 20y 2d
Flared trousers..... I remember that. :spoton:
in this case.... the box doesn't hook up in 3rd - by the sound of it....
Puls - unless there's something whacky going on with your change tables, you have a rebuild coming - so save your pennies and do it right..... as per geea's suggestion.
