  • Member For: 19y 10m 8d
I have a noise and vibration that is only really evident between 75 and 85 km/hr. The noise is like the wheel going around and touching something every 0.7 sec.........I can't pinpoint the noise (seems general) and even youngy could feel the vibration in the passenger seat. It does the same thing in any gear so long as your doing 75 - 85.
I've checked under the car thoroughly and the only thing I spot is an issue with the tailshaft - diff joint). There is these small plastic looking clips and they seem to be missing on one side. I have not got a digital camera here so I can't post photos.
Could this be the issue.....small plastic clips??......can someone please check if they have these on all sides of the shaft/diff joint.
Much appreciated cheers lads.
https://www.fordxr6turbo.com/forum/topic/25455-tailshaft-diff/
  • BOOST
  • Moderating Team
  • Member For: 21y 8m 11d
Had a quick look but did not have the best light. Yes I used a torch
Ill have a squiz in the morning and let you know how I go
Rob
  • It's All In Your Mind
  • Member For: 21y 6m 17d
The small plastic things are the balancing weights, maybe a couple fell off. I have had the same issue in my Typhoon between 100-110 then from 160 plus. They have checked everything and can't figure it. :kissmy:
It;s going back in for G/Box, Diff, Clutch and Pressure Plate checks next week :glad:
Thanks heaps for the feedback guys. I jumped under my brothers ute but the live axle doesn't use the plastic clips.
160 on.... ha haa classic!!! Whats it like at 260!!!!!! Where are you taking yours for a check??
I'm sure I've seen you around on the streets before too!!
Mate I've had the thing in 6th with the speedo needle on the stop at 270 and it's like having a concrete mixer in the boot :tease: , bit toooooooo hairy at that speed for more than a couple of seconds, just in case something broke :spoton:
The car has been ripped apart from one end to the other and everything checked more than once trying to find this vibration. Back to hospital for another week on Monday while I'm in Bris Vegas :msm:
  • Member For: 19y 10m 27d
Mate I've had the thing in 6th with the speedo needle on the stop at 270 and it's like having a concrete mixer in the boot :spit: , bit toooooooo hairy at that speed for more than a couple of seconds, just in case something broke :spoton:
The car has been ripped apart from one end to the other and everything checked more than once trying to find this vibration. Back to hospital for another week on Monday while I'm in Bris Vegas :spoton:
Hi guys my F6 has the same prob,, they cant find it ,,they said bring it back on the 30,000 ks service ,wait & see if it gets worse at that point,only done my 15,000 ks service 6 weeks ago,,They have no idea what there looking at :gooff:
  XXXR6T said:
When did this start happening? Shortly after some mysterious smoke came from the back of the car? :spoton: :spoton:
I though it had something to do with the bush I ran over myself.!!!!!.....but I didn't notice it straight away???? Surely this must have caused it but there is not a scratch underneath the car anywhere (besides when the engine was removed!!!!)
I dont know, but I first want to know if these plastic clips/weights are found all around the tailshaft / diff joint. I'll take it to ford and see what they reckon.
As for 260.......crikey
