Dba 4000 Rotors
Cro
  • Member For: 19y 11m 3d
I'd definitely get the slotted rotors for their additional cooling abilities, etc - the fact that they also look so much better is an added bonus!
As for pads, I think any performance pad is going to be pretty dusty - just the price you pay for improved braking performance. I have the 'standard' pads supplied by PBR with their 'premium' brake kit and they're dusty as hell too.
  • 1 month later...
  • Member For: 17y 11m 16d
hello all im geting new rotors and have been oftered cross drilled rotors for the same price as just slotted for street use only should I take them .....will they crack and do they work just as good as the slotted ones besides looking better or am I best just sticking with the slotted only ones
cheers trev
  • CNUTOX
  • Member For: 22y 3m
Slotted or the sh*tty holes will get cracks around them.
Dba drill the holes after the disc is made, whereas Brembo for instance have the holes in the moulding process so are heat treated etc properly.
  • My engine bay is Bionic
  • Member For: 19y 18d
The metallurgy of the discs is now of a good enough quality that drilled rotors are no longer required. Even the V8 supercars no longer use drilled rotors. Cars that use drilled rotors only do so for the look.
I.B.
  • Formerly XR6NA
  • Member For: 19y 4m 7d
  R-SPEC said:
:innocent: but if you're gonna get DBA get the 5000 series
Won't fit on BA's/BF standard brakes. I wanted to get them as well but race brakes sydney said won't work.
I.B.
But if you get the drilled you risk cracking between the holes whereas the slotted wont crack and will do a better job. For the street, the DBA 4000 slotted are an excellent choice that many on here have done. Next you will have pad choice.
I.B.
  • Formerly XR6NA
I should clarify that is for the T's brakes. The 5000's are fine for typhoons.
