  • Member For: 20y 3m 15d
Hey guys, a couple of months ago I had a Nizpro edit and tune done on my T which I was delighted with, the engine now seems to have a slight ping under heavy acceleration which it didn't do after the custom tune. I am not sure whether it is the petrol or whether I should return to Nizpro and get the lads to check it out. Is this potentially damaging even though it is only minimal pinging and only when given it some stick. Your advice would be appreciated.
Thanks
Deano
https://www.fordxr6turbo.com/forum/topic/25349-engine-pinging/
  • Here since the start...
  • Member For: 22y 20d
Yes... Pontentially.
I would give them a call. I'm sure they'll fix it for you without any dramas.
  • Playing with Sports Bikes...
  • Member For: 19y 6m 17d
  Quote
Thanks
Deano
Hey Deano...
In your CAPA flash box you should have a 95RON tune, which won't be as aggresive a tune as the 98RON tune, maybe it would be a good idea to load that tune in until you can get it to them...
Are you a member of the Nizpro Forum? If not, then maybe it's also worth joining there and posting the problem asking for their advice directly...
Good luck with it mate!
Jack :fool:
  • Member For: 21y 3m 15d
thank god it wasnt someone elses tune that was slightly pinging... he would of been flamed!!!!
get it checked out... am sure your tuner will fix it for you :spoton:
  • Sucker
  • Moderating Team
  • Member For: 21y 21d
get it checked out... am sure your tuner will fix it for you :blush:
Not to forget the fact that this thread would be up to three pages by now as well :spoton:
  • Member For: 21y 10m 19d
A thread like this almost always attracts the crabs.
Definitely get it seen to. Until then you can either:
- Flash the car to a softer tune
- Take it easy
- Try a different fuel/supplier
- Run some octane boost.
  • Member of team Kittens
  • Member For: 21y 2m 23d
give the boys a call on Monday, as Jack suggested, flash in the 95 tune.
If actual fuel quality is lower than about 96, I would expect you will get slight pinging on a 98 tune. :blush:
This is normal but not good, and why you should have a 95 tune to flash if you cant get 98 fuel or get a bad batch. :spoton:
You also may just want to run that fuel through - drive it easy in the mean time!!
Let us know how it goes!
Cheers,
Ben.
