Guest Guests Posted 04/05/06 02:55 PM Share Posted 04/05/06 02:55 PM Hi,Gear Drives , what do they do, and are they of any real benefit to a XR6T / F6?Darren Link to comment Share on other sites More sharing options...
Robit28 Member 385 Member For: 19y 2m 9d Location: Brisbane Posted 04/05/06 03:12 PM Share Posted 04/05/06 03:12 PM Gear Drives? I suppose you're talking about Gilmer drives. If so, the advantage of these is they have toothed gears on the pulley wheels to stop slippage. They are designed for supercharger drives due to the force needed to turn the superchargers turbines. On an XR6T, well, I don't think there would be any advantage except for cosmetic and the 'supercharger' belt sound, but you wouldn't want that on a turbo car anyway.I think that's what you are referring to anyhow????Rob. Link to comment Share on other sites More sharing options...
Goobz Member 746 Member For: 20y 2m 28d Location: Sutherland Shire, Sydney Posted 04/05/06 08:22 PM Share Posted 04/05/06 08:22 PM I would have though he meant the gear drive they use to drive the cam on a single cam V8. Dont think you can get them for an overhead cam engine. I could be wrong though...Chris Link to comment Share on other sites More sharing options...
ZAP No boost, no bottle, just my foot on the throttle! Lifetime Members 7,935 Member For: 20y 10m 25d Gender: Male Location: Sydney Posted 04/05/06 10:39 PM Share Posted 04/05/06 10:39 PM I think the gear drives Darren is referring to are the type that you hear on chevies and sound like they are supercharged.Most pushrod motors use a chain drive and sprockets to link the camshaft with the crank. Geardrives replace the chain and sprockets and give a direct drive via gears, usually straight cut...this is why they have a whirring sound. They use geardrives to prevent chain breakage and slop.A lot of owners get it for the supercharged noise they make. Link to comment Share on other sites More sharing options...
MrBean Member 400 Member For: 18y 8m 2d Location: Melbourne Posted 06/05/06 11:15 PM Share Posted 06/05/06 11:15 PM My 1st post here - helloI know Pete Jackson made a good set of geardrives for 350 Chevies, 351 Fords. They are superior to chaindrives in the sense they don't stretch, resulting in bad cam-timing.Nowadays true roller-chains are getting close to the same reliability as gear drives. Geardrives will have an advantage where very aggressive cams are used, with hefty valvesprings , especially in turbocharged engines where you are running huge 2.02"Intakes, and high bosst-pressures.You will need good quality dual-or triple springs, which will wear out a chain in relatively short time, but geardrives will last a lot longer. They are typically more noisier though, quite ok for the dragstrip, but sh*tty when you go on a 700km trip Anyway same as Zap F6's reply. Link to comment Share on other sites More sharing options...
God666 Complete Bastard Donating Members 1,123 Member For: 21y 1m 4d Gender: Male Location: Sydney Posted 07/05/06 12:21 PM Share Posted 07/05/06 12:21 PM A lot of owners get it for the supercharged noise they make.←Sounds more like you have a Hercus lathe stuck under the bonnet! Link to comment Share on other sites More sharing options...
docoom Member 12 Member For: 18y 6m 14d Posted 28/06/06 11:16 AM Share Posted 28/06/06 11:16 AM A lot of owners get it for the supercharged noise they make.←Sounds more like you have a Hercus lathe stuck under the bonnet!←HEY !!!!! I love the sound of my hercus lathe. and it scare's the boy racers off coz they not sure whats lurking under the bonnet Link to comment Share on other sites More sharing options...
Ninka Donating Members 1,850 Member For: 22y 16d Gender: Male Location: Perth, WA Posted 29/06/06 02:08 AM Share Posted 29/06/06 02:08 AM Hi,Gear Drives , what do they do, and are they of any real benefit to a XR6T / F6?Darren←Hmm let's see - You have gear drives in your gearbox, really useful coz without you go NOWHERE.Next you have gear drives in your diff, without which you go NOWHERE, so to summarise - GEAR DRIVES ARE REALLY USEFUL THINGS in an XR6T Sorry Darren, dumb question = Dumb answer Link to comment Share on other sites More sharing options...
Guest Guests Posted 29/06/06 02:20 AM Share Posted 29/06/06 02:20 AM Hi,Gear Drives , what do they do, and are they of any real benefit to a XR6T / F6?Darren←Hmm let's see - You have gear drives in your gearbox, really useful coz without you go NOWHERE.Next you have gear drives in your diff, without which you go NOWHERE, so to summarise - GEAR DRIVES ARE REALLY USEFUL THINGS in an XR6T Sorry Darren, dumb question = Dumb answer ←Well if you say so,I guess not only was it a dumb question, but also a genuine one at that. I was unaware of 'gear drives' as such being available in gearbox or diff, I'll leave that to those that are mechanically minded. The gear drives I was referring to, apparently are 'perfectly timed' and do have certain clicking and whining noise.But thanks for steering me in the right direction though! Darren Link to comment Share on other sites More sharing options...
Chris xr6 Member 376 Member For: 20y 9m 9d Location: Shire Posted 29/06/06 02:24 AM Share Posted 29/06/06 02:24 AM Basic mechanical knowledge goes a long way! Link to comment Share on other sites More sharing options...
