What A Good Drag Tyre
fordperformer
  • - Track Bound EVO III -
  • Member For: 20y 1m 13d
what's your best time as it stands??
most popular is the 17", but in our utes, not good for drags.
16" 255/50/16. $300 each and will help gearing out for drags.
Look out for the clutch.
is this what you use & are they m/t et street radial . I;ve priced some for $283
They are M/T's and ideally they are what I would run..
If I can go down next week and grab 12.50-12.80 on my everyday road tyres, I might consider doing something about some 16's but in all reality, our track closes for winter soon and the strain it will put on the driveline, ie clutch might be a backward step..
  • 3 weeks later...
  • Replies 25
  • Member For: 19y 2m 24d
Why do you say not good for the utes? taller diff ratio? I thought the utes (ba ) had the sade as the sedans?
I have only used mine once, they dropped my 0 ft from 2.3 to 2.05 Stock auto and stall, pretty dull tune too, launched at 2250rpm.
MT 275-45-17 ET radials at 20PSI
3.73, yes 6spd manual sedan gets the same but we have shorter gearing in the F6's compared to the T. ( remember the special 'close ratio' gearbox FPV rave about... )
Hence why I said 'our' utes :)
I saw another post where he ran 13.6 at 113, so question answered.. :spoton:
Got some MT 275-40-17 et streets & rims will try them out , let you know , traction has been a problem mainly also because I got a lighter tray ( alloy on board ) not factory style side . hopefully get some good times down
Edited by fordperformer
  • 2 months later...
finally make some time to go back to the track with new wheels & e/t street slicks with 13 psi & installed new tunes 301 rwkw ( thanks simon ) best run tune 3 12.8 - 109 m/h . description of run yellow yellow 4200 rpm dump clutch green light go!!! got out of hole great reaction .468 - 60 ft 1.878 second bogged down a bit ( need too work on gear changes , next tune ajustment bring power on earlier ) third gear same , four gear same but o.k feeels ggreat . running over line . what a rush , :msm: wind down windows ... line up again , looking for shortest queue . best part is room for improvement :stirthepot:
thanks  tried to find one of your old posts  re your techique & ideas can you remember what forumn & when , these f6 's are great cars
Driving a Manual Linky
You might have to look at the 11.8 thread for the MT techniques.
Effectivly load it up to 4500rpm, step off the clutch. Change around 4800rpm, or juuust after at peak torque on your dyno graph.
You have to pedal faster than Fred Flintstone in an oil bath!!!
Hang on till the end, do it again..
:laughing:
  • Team Grandpa
  • Member For: 18y 8m 29d
$279 from these guys shipped to my door $27.
https://www.americanautos.com.au
I ended up getting mine for $264 ea. they have come down, maybe due to the US$$??
