cobrav8 Member 1,969 Member For: 20y 1m 15d Gender: Male Location: New Zealand Posted 02/05/06 09:42 AM Share Posted 02/05/06 09:42 AM boosted_sa said: cobrav8 said: If you guys are cutting chunks out of the bar - why not replace it with some reinforcing above and/or below the intercooler?←not sure what you mean? how would you reinforce it. there isn't a lot of room above and below the cooler.←well - maybe even a brace from side to side behind the radiator?It seems that this is a fairly stuctural piece being cut into here. Link to comment https://www.fordxr6turbo.com/forum/topic/25023-will-i-get-this-to-fit/page/3/#findComment-376765 Share on other sites More sharing options...
turbotrana Member 2,586 Member For: 22y 1m 9d Gender: Male Posted 02/05/06 11:58 AM Share Posted 02/05/06 11:58 AM The other option is to cut the whole bar out (which is about 3" thick) and weld in a thinner bar made out of thicker steel. But then getting it engineered is a pain. cobrav8 said: boosted_sa said: cobrav8 said: If you guys are cutting chunks out of the bar - why not replace it with some reinforcing above and/or below the intercooler?←not sure what you mean? how would you reinforce it. there isn't a lot of room above and below the cooler.←well - maybe even a brace from side to side behind the radiator?It seems that this is a fairly stuctural piece being cut into here.← Link to comment https://www.fordxr6turbo.com/forum/topic/25023-will-i-get-this-to-fit/page/3/#findComment-376816 Share on other sites More sharing options...
boosted_sa Member 270 Member For: 19y 9m 20d Posted 02/05/06 01:24 PM Share Posted 02/05/06 01:24 PM now we're talking!!! cut it all up Seriously, it would be an excellent idea! Engineering would be a pain, but as I always say what they don't see doesn't hurt them :rokon: if you did replace the bar you'd fit almost any thing you want behind there!mmm so many ideas! turbotrana said: The other option is to cut the whole bar out (which is about 3" thick) and weld in a thinner bar made out of thicker steel. But then getting it engineered is a pain. Quote Link to comment https://www.fordxr6turbo.com/forum/topic/25023-will-i-get-this-to-fit/page/3/#findComment-376850 Share on other sites More sharing options...
rushed6 Member 137 Member For: 19y 8m 16d Gender: Male Location: Victoria Posted 03/05/06 09:44 AM Share Posted 03/05/06 09:44 AM XXXR6T said: rushed6 said: nah the cond pipes are easy to by pass well that is being a fridgy I deal with this sh*t al the time heres my pics I ran the pipes into the existing ones←Isn't the intercooler's effectiveness halved? Lookes like it's half covered up...←read my other post it was installed for looks I never wanted my ute to be a drag car 260kw at the wheels is good enough for me if you wanna install one cut the bar out I chose not to. and it worked I could get 300 out the ute with the way my cooler was set up but the auto would not handel the torque and beefing up the auto is not currently in my budget. Link to comment https://www.fordxr6turbo.com/forum/topic/25023-will-i-get-this-to-fit/page/3/#findComment-377069 Share on other sites More sharing options...
