tab Sucker Moderating Team 32,303 Member For: 20y 5m 4d Gender: Male Location: Brisbane Posted 24/04/06 09:48 AM Share Posted 24/04/06 09:48 AM Drilling in the firewall? Even my uneducated mind tells me that's not a grand idea Link to comment Share on other sites More sharing options...
Max Power Member 381 Member For: 20y 4m 27d Location: MENAI, NSW Posted 28/04/06 08:32 AM Share Posted 28/04/06 08:32 AM In a manual when you drill holes in firewall be careful of hitting pipes and fingers with drill bit :S Not that id know nething about that ←I dont agree.The best way is through the rubber grommet above the right kick panel and inside the right guard coming out near the headlight. This way no holes in firewall.←Do you have any photos of the grommet. I dont like the idea of drilling holes,Thanx←No photos, sorry!All I can say is it will all become apparent what needs to be done when the plastic cover on the underside of the drivers' side guard is removed. Looking back towards the front door, there will be a wiring loom going into the cabin, in the kick panel location, via a large rubber grommet. You will have enough room on the side of the grommet to make a hole and pass your amp wire through. With the plastic cover still removed, secure the wire along the inside of the guard up to the hole inside the engine bay near the battery and right headlight.Regards,Arthur Link to comment Share on other sites More sharing options...
turbotrana Member 2,586 Member For: 21y 5m 30d Gender: Male Posted 28/04/06 10:05 AM Share Posted 28/04/06 10:05 AM how about the guy who drilled a hole in the firewall to have the drill hit a major wiring harness chewing the harness and shorting a number of electrical bits. He didn't even disconect the bat. I think this was on a late model vehicle also. Link to comment Share on other sites More sharing options...
XR06T Silver Donating Members 4,146 Member For: 19y 3m 7d Gender: Male Posted 30/04/06 03:37 AM Share Posted 30/04/06 03:37 AM In a manual when you drill holes in firewall be careful of hitting pipes and fingers with drill bit :S Not that id know nething about that ←I dont agree.The best way is through the rubber grommet above the right kick panel and inside the right guard coming out near the headlight. This way no holes in firewall.←Do you have any photos of the grommet. I dont like the idea of drilling holes,Thanx←No photos, sorry!All I can say is it will all become apparent what needs to be done when the plastic cover on the underside of the drivers' side guard is removed. Looking back towards the front door, there will be a wiring loom going into the cabin, in the kick panel location, via a large rubber grommet. You will have enough room on the side of the grommet to make a hole and pass your amp wire through. With the plastic cover still removed, secure the wire along the inside of the guard up to the hole inside the engine bay near the battery and right headlight.Regards,Arthur←this is evactly what I did and once the drivers wheel is off and the plastic guard removed its v obvious what you gotta do..ends up neat as in the engine bay too! Link to comment Share on other sites More sharing options...
51KBA 2005 BA MK11 turbo Member 140 Member For: 18y 8m 25d Gender: Male Location: sunshine coast Posted 11/06/06 08:41 AM Share Posted 11/06/06 08:41 AM In a manual when you drill holes in firewall be careful of hitting pipes and fingers with drill bit :S Not that id know nething about that ←I dont agree.The best way is through the rubber grommet above the right kick panel and inside the right guard coming out near the headlight. This way no holes in firewall.←that's where maroochy car sound ran mine works a treat Link to comment Share on other sites More sharing options...
