Garfield Member 17 Member For: 18y 9m 16d Location: Brisbane Posted 19/04/06 01:11 AM Share Posted 19/04/06 01:11 AM Hi, just got myself an MKII T Auto. From what I have read it appears the first place to start mods is the auto trans. I plan to get a CAPA Flasher which seems to have a positive affect on the trans. So I thought I would try to reduce the heat level.I am looking at fitting a Davis Craig trans cooler or is the genuine Ford unit OK?The most logical position to fit it is directly behind the main (upper) grille. I don't what to have to add fans and switches etc. Do you feel that this position would be OK, and would you need add some trans oil to maintain correct levels and if so how?Any advise will be appreciated! Link to comment Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,323 Member For: 19y 4m 11d Gender: Male Location: Perth Posted 19/04/06 01:19 AM Share Posted 19/04/06 01:19 AM try using the search function mate. Theres a heap of info on here about trans coolers and where to mount them If you dont get the results try using the advanced search functions.... Link to comment Share on other sites More sharing options...
Garfield Member 17 Member For: 18y 9m 16d Location: Brisbane Posted 19/04/06 01:37 AM Author Share Posted 19/04/06 01:37 AM Good idea! But I did try the search fuction and ya I did find some threads that started on the topic of trans coolers. But unfortuneatly they seemed to go off the topic at hand and therefore never really answered the question!If you could help point me in the right direction it would be a great help! Link to comment Share on other sites More sharing options...
geea Site protagonist Lifetime Members 4,320 Member For: 21y 8m 22d Gender: Male Location: At the lights, waiting for you. Posted 19/04/06 03:25 AM Share Posted 19/04/06 03:25 AM I have mine mounted infront of the intercooler in the big opening.Geea. Link to comment Share on other sites More sharing options...
thebrunks Member 665 Member For: 20y 6m 23d Location: Gold Coast Posted 19/04/06 03:32 AM Share Posted 19/04/06 03:32 AM Ian (Goldie) does the best trans cooler setup!!He runs it to the rear & uses an electric fan to flow air. Seeing as most the heat is generated at bugger all car speed I'd suggest an electric fan!Russ Link to comment Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,323 Member For: 19y 4m 11d Gender: Male Location: Perth Posted 19/04/06 06:03 AM Share Posted 19/04/06 06:03 AM Good idea! But I did try the search fuction and ya I did find some threads that started on the topic of trans coolers. But unfortuneatly they seemed to go off the topic at hand and therefore never really answered the question!If you could help point me in the right direction it would be a great help! ←try this thread.....go to page 2.http://www.fordxr6turbo.com/forum/index.ph...pic=21140&st=18dannopower and i have similar setups with a thermo fan to help the cooling.... others on here have gone for in front/above the cooler mounting...couldnt be bothered finding those threads....im sure somebody who had done that will find this thread and post something for you.... Link to comment Share on other sites More sharing options...
