  • Replies 34
  • Member For: 19y 7m 8d
  XXXR6T said:
Sweet, thanks heaps :spoton:
I messed around with designs and shapes but couldnt get it to go... mind you I was planning on 2x12" subs so the angle would be greater.
If u have the design drawn that would be tops :glad:
the designs for the box were thrown out before easter but I did take some external mesurements for you.
The box is 285mm high x 800mm wide. its too hard for me to mesure how deep it goes but im sure its 420mm at the bottom and 370mm at the top. The internal volume is around 70L and the box is sealed.
I have the subs firing to the rear and the sloped section of the box is facing the rear seat. There is also enough room to mount the amp on the box so that when you pull the seat back down there is something there to look at :blush:
