Frankg Member 20 Member For: 21y 11m 8d Location: Adelaide Posted 13/04/06 04:52 AM Share Posted 13/04/06 04:52 AM Dont know how many of you have been following my bent rods post about replacing engine and now turbo...But I have another issue regarding the brakes / brake shudder... That has left an even worse taste in my mouth...!!!After Jarvis having my car for the bent rods issue it was also due to be serviced... now firsly they have told me that the rotors are too thin and need replacement... I told them yes of course they are you idiots (ford) has machined them twice already... now they agreed and said they would be replaced under warranty...This is where the bullsh*t starts.. becasue they also told me that the brake pads only had 3mm left and I would have to replace them as well...I thought what the???I was confused as I knew that they had replaced them before at the 75k service under warranty... and now only 15k later they needed replacing again!!!!This doesnt make sense to me??? how come the original ones lasted to 75 K atleast and now these will have to be replaced every 15K!!!! They are also $300.00 for the pair I have been told... although he did reduce it to $250.00 for me in the end... So what I can see is that ford have fixed the brake shudder problem by installing extremely expensive and soft brake pads are are going to make all of us pay for it!!!!! I am absolutely Pissed about this and I will be contacting cosumer affairs and taking it further...anyone else want to join me??? Has anyone else actually had a decent fix done by ford for this??Anyone any comments help... I will never buy a freekin ford again for sure!!!!! Link to comment https://www.fordxr6turbo.com/forum/topic/24700-brake-shudder-brake-pads-expensive/ Share on other sites More sharing options...
ColinT Donating Members 372 Member For: 20y 4m 27d Posted 13/04/06 05:33 AM Share Posted 13/04/06 05:33 AM I found this out about the Ford fix a while ago and posted the details.Yes they machine the pads and change to a different compound for the pads. But this is suppost to stop the shudder reappearing. Link to comment https://www.fordxr6turbo.com/forum/topic/24700-brake-shudder-brake-pads-expensive/#findComment-370135 Share on other sites More sharing options...
Adam Here since the start... Lifetime Members 10,282 Member For: 22y 2m 3d Gender: Male Location: Victoria Posted 13/04/06 06:30 AM Share Posted 13/04/06 06:30 AM I don't think your pads got changed at the 75k service at all. Link to comment https://www.fordxr6turbo.com/forum/topic/24700-brake-shudder-brake-pads-expensive/#findComment-370146 Share on other sites More sharing options...
kawerx TerriGhia Donating Members 206 Member For: 19y 5m 7d Posted 13/04/06 09:52 AM Share Posted 13/04/06 09:52 AM its called a phantom Link to comment https://www.fordxr6turbo.com/forum/topic/24700-brake-shudder-brake-pads-expensive/#findComment-370241 Share on other sites More sharing options...
EvilDaifu Cruise Whore Moderating Team 5,130 Member For: 19y 10m 23d Gender: Male Location: Melbourne Posted 13/04/06 10:14 AM Share Posted 13/04/06 10:14 AM I had a BA XR6 for 12 months with very bad chronic brake shudder. Nothing Ford did resolved it as it would reappear after about 5000 to 8000km after being machined. I don't have the BA XR6 anymore. The day the lease ended it was at Ford being repaired because the brakes had failed. Something about the brake line needing replacing. About 3 days before the lease was up, I braked at 60km/h and the foot sunk to the floor but the car kept rolling forward - albeit a coming to slow stop under manual foot pressure Don't even want to think what would have happened if I was driving at 100km/h Because they were taking so long to repair it (and did not supply me with a courtesy car), I said to them "Don't worry, you can keep it." On the 3rd day, I picked up the BF XR6T (from the same dealership which made it easy to transfer my gear from the BA to the BF). Thank goodness the Territory brakes on the BF don't seem to suffer from brake shudder. Link to comment https://www.fordxr6turbo.com/forum/topic/24700-brake-shudder-brake-pads-expensive/#findComment-370263 Share on other sites More sharing options...
built2redline Member 187 Member For: 20y 1m 24d Location: sh*tney Posted 13/04/06 12:31 PM Share Posted 13/04/06 12:31 PM bendix ultimates (kevlar material, exelent braking even when punished hard) from $158 to $189 from your local repco.much cheaper option, much better brake pads.it amases me ppl continually complain about the brake suhdder on the BA, when for a total of $480 you can get rid of the problem once and for all,$300 for DBA slotted rotors, 180 for bendix ultimate brake pads. I know youre gonna say "warranty mate" but how much do you value your time of having to take your car to the dealer time and time again only to have the same problem re-occur.I dunno about you but $480 seems worth it Link to comment https://www.fordxr6turbo.com/forum/topic/24700-brake-shudder-brake-pads-expensive/#findComment-370345 Share on other sites More sharing options...
teeg Member 372 Member For: 19y 11m 17d Location: SA Posted 13/04/06 10:17 PM Share Posted 13/04/06 10:17 PM Frankg said: Dont know how many of you have been following my bent rods post about replacing engine and now turbo...But I have another issue regarding the brakes / brake shudder... That has left an even worse taste in my mouth...!!!After Jarvis having my car for the bent rods issue it was also due to be serviced... now firsly they have told me that the rotors are too thin and need replacement... I told them yes of course they are you idiots (ford) has machined them twice already... now they agreed and said they would be replaced under warranty...This is where the bullsh*t starts.. becasue they also told me that the brake pads only had 3mm left and I would have to replace them as well...I thought what the???I was confused as I knew that they had replaced them before at the 75k service under warranty... and now only 15k later they needed replacing again!!!!This doesnt make sense to me??? how come the original ones lasted to 75 K atleast and now these will have to be replaced every 15K!!!! They are also $300.00 for the pair I have been told... although he did reduce it to $250.00 for me in the end... So what I can see is that ford have fixed the brake shudder problem by installing extremely expensive and soft brake pads are are going to make all of us pay for it!!!!! I am absolutely Pissed about this and I will be contacting cosumer affairs and taking it further...anyone else want to join me??? Has anyone else actually had a decent fix done by ford for this??Anyone any comments help... I will never buy a freekin ford again for sure!!!!!←one problem I see in all this is the word Jarvis, I haven't had very good experiences with them in the past and now travel the other side of town to maughan thiem whom see to be doing alright so far. Link to comment https://www.fordxr6turbo.com/forum/topic/24700-brake-shudder-brake-pads-expensive/#findComment-370407 Share on other sites More sharing options...
bangm001 Member 307 Member For: 19y 6m 23d Posted 13/04/06 11:26 PM Share Posted 13/04/06 11:26 PM Nah, I like my "factory" SQUEALING brakes better. ALready taken it back once, will be again at the 15 thou service, but dont have the shudder all you guys are talkin about. Link to comment https://www.fordxr6turbo.com/forum/topic/24700-brake-shudder-brake-pads-expensive/#findComment-370416 Share on other sites More sharing options...
BADGERSXR6TUTE Member 209 Member For: 21y 3m 16d Location: llandaff, tasmania Posted 14/04/06 12:07 AM Share Posted 14/04/06 12:07 AM built2redline said: bendix ultimates (kevlar material, exelent braking even when punished hard) from $158 to $189 from your local repco.much cheaper option, much better brake pads.it amases me ppl continually complain about the brake suhdder on the BA, when for a total of $480 you can get rid of the problem once and for all,$300 for DBA slotted rotors, 180 for bendix ultimate brake pads. I know youre gonna say "warranty mate" but how much do you value your time of having to take your car to the dealer time and time again only to have the same problem re-occur.I dunno about you but $480 seems worth it←Well said mate, exactly what I have done, would recommend it to anyone sure beats shudder. Link to comment https://www.fordxr6turbo.com/forum/topic/24700-brake-shudder-brake-pads-expensive/#findComment-370421 Share on other sites More sharing options...
Goldbullet Member 883 Member For: 20y 3m 5d Location: Frankston Posted 14/04/06 01:15 AM Share Posted 14/04/06 01:15 AM I judt got new pad's for my Brembos front pads only they are made out of ceramic and come on the Ferrari 550 as standard cost $720 front pads only .But they do work great.Dave. Link to comment https://www.fordxr6turbo.com/forum/topic/24700-brake-shudder-brake-pads-expensive/#findComment-370442 Share on other sites More sharing options...
