IBTZNU Member 14 Member For: 15y 9m 30d Gender: Male Posted 22/06/09 01:11 PM Share Posted 22/06/09 01:11 PM hi guys, I got an Fg XR6 turbo wot is better to have installed a BOV or a Flutter?Thanks Link to comment https://www.fordxr6turbo.com/forum/topic/24608-turbo-flutter-and-blow-off-valves/page/6/#findComment-894859 Share on other sites More sharing options...
PHANTMXR6 It's not a MKI! Member 1,742 Member For: 16y 10m 2d Gender: Male Location: Earth Posted 22/06/09 01:38 PM Share Posted 22/06/09 01:38 PM lol at the flutter.You can try this yourself and see what sounds better to you.First you have to remove the BOV and plug the two hoses and the signal line.Then you get in your car and go for a drive building up boost and stepping off the throttle pedal.You will hear gobble gobble noises commonly referred to as flutter. Won't be much as stock boost isn't very high.If you want the silly pssst sound of a vented BOV then you'll need something like a Turbosmart Kompact series dual port BOV. It will fit into the factory BOV position no problems. Then you go for another drive and repeat the process. Build up boost and step off the throttle pedal. Now you will here the annoying pssst everytime you are on boost and step of the throttle.The bonus with the Kompact series dual port is if you get sick of the annoying pssst you can cap the trumpet port with the plug that came with it.But to answer your question, a BOV is better to have installed. Link to comment https://www.fordxr6turbo.com/forum/topic/24608-turbo-flutter-and-blow-off-valves/page/6/#findComment-894899 Share on other sites More sharing options...
Ricks_Xr6t Member 101 Member For: 16y 3m 4d Gender: Male Location: Karratha,W.A. Posted 01/08/09 01:51 PM Share Posted 01/08/09 01:51 PM Simon at Nizpro stated somewhere on his own forum's that a BOV on the barra 6t's that a BOV is as restrictive as a centre muffler,you dont need it.that was his words but I have the same BOV as you PHANTM and yes it is vented running a twin air 6 inch pod and 4 inch piping so she sneezes fairly loud for standard boost.Hows your car going? Link to comment https://www.fordxr6turbo.com/forum/topic/24608-turbo-flutter-and-blow-off-valves/page/6/#findComment-915459 Share on other sites More sharing options...
PHANTMXR6 It's not a MKI! Member 1,742 Member For: 16y 10m 2d Gender: Male Location: Earth Posted 01/08/09 03:47 PM Share Posted 01/08/09 03:47 PM 26000+ and all good mate. Doesn't get driven much nowadays.I tonk around in the missus Territory.Boat gets more use than the car. lol Link to comment https://www.fordxr6turbo.com/forum/topic/24608-turbo-flutter-and-blow-off-valves/page/6/#findComment-915473 Share on other sites More sharing options...
RUS531 RUS531 Donating Members 410 Member For: 18y 8m 2d Gender: Male Location: Emerald QLD Posted 10/08/09 10:23 AM Share Posted 10/08/09 10:23 AM Ok I've been reading and am confused about a few things.Firstly, it was said that at cruise the BOV is held open therefore bypassing the turbo, if you had a BOV like the TS dual port, would it suck in unfiltered air? Or is the TS BOV designed in such a way that it does perform the same way as the stock setup.Secondly, correct me if I'm wrong, but going on what Simon said, if we have vented BOVs it does not affect emissions due to the MAP sensor being after the TB, therefore the car doesn't go rich for that moment. Could someone explain if this is correct or not. If it is not an emissions issue on these cars why do people get booked for venting the BOV to the atmosphere? The only reason I could think of is making excessive noise?CheersCameron Link to comment https://www.fordxr6turbo.com/forum/topic/24608-turbo-flutter-and-blow-off-valves/page/6/#findComment-918956 Share on other sites More sharing options...
RUS531 RUS531 Donating Members 410 Member For: 18y 8m 2d Gender: Male Location: Emerald QLD Posted 14/08/09 07:01 AM Share Posted 14/08/09 07:01 AM anyone? Link to comment https://www.fordxr6turbo.com/forum/topic/24608-turbo-flutter-and-blow-off-valves/page/6/#findComment-920526 Share on other sites More sharing options...
SuckSqueezeBangBlow ʎǝʞuoɯ ɹoıuǝs Donating Members 1,808 Member For: 16y 4m 5d Gender: Male Posted 14/08/09 08:24 AM Share Posted 14/08/09 08:24 AM yes, noise pollution. Link to comment https://www.fordxr6turbo.com/forum/topic/24608-turbo-flutter-and-blow-off-valves/page/6/#findComment-920558 Share on other sites More sharing options...
Ricks_Xr6t Member 101 Member For: 16y 3m 4d Gender: Male Location: Karratha,W.A. Posted 14/08/09 11:51 PM Share Posted 14/08/09 11:51 PM 26000+ and all good mate. Doesn't get driven much nowadays.I tonk around in the missus Territory.Boat gets more use than the car. lolDont blame you there mate,ya cant beat NorthWest fishing Link to comment https://www.fordxr6turbo.com/forum/topic/24608-turbo-flutter-and-blow-off-valves/page/6/#findComment-920758 Share on other sites More sharing options...
PHANTMXR6 It's not a MKI! Member 1,742 Member For: 16y 10m 2d Gender: Male Location: Earth Posted 15/08/09 12:10 AM Share Posted 15/08/09 12:10 AM No rodholders on this baby. Link to comment https://www.fordxr6turbo.com/forum/topic/24608-turbo-flutter-and-blow-off-valves/page/6/#findComment-920764 Share on other sites More sharing options...
Dillz Three pedals are better then two.. Donating Members 15,637 Member For: 17y 10m 27d Gender: Male Location: Melbourne Posted 15/08/09 12:26 AM Share Posted 15/08/09 12:26 AM Ok I've been reading and am confused about a few things.Firstly, it was said that at cruise the BOV is held open therefore bypassing the turboCheersCameronWTF?? How would that happen??And bovs don't suck in air, that's what turbos are for. Only negative of a bov is the noise. Link to comment https://www.fordxr6turbo.com/forum/topic/24608-turbo-flutter-and-blow-off-valves/page/6/#findComment-920767 Share on other sites More sharing options...
