Turbo Flutter and Blow Off Valves
DaRKy
  • Here since the start...
  • Member For: 21y 9m 9d
Adam sticky it if you think its worthwhile.
Done.
I've also adjusted the title and moved it to the Modifications & Workshop section. :spoton:
  • 1 month later...
  • Member For: 19y 6m 27d
I did some experimenting today and discovered the following using a K&N pod where the airbox is and a turbosmart (TS) kompack BOV:
Std paper Filter + Std BOV = tiny bit of gobble gobble :tosser:
Pod + Std BOV = gobble gobble (loud compared to panel K&N) :spoton:
Pod + TS BOV = Pssshhhh + very tiny bit of gobble. :spoton:
Pod + no BOV = Loud rattle snake :spoton:
Std paper Filter + no BOV = very tiny bit of rattle snake. :fool:
Std paper Filter + TS BOV = Loose setting (Pssshhhh...Pssshhhh) tight setting (Pssshhhh) :w00t2:
No intake pipe + TS BOV = explosion of psshhh + rattle snake :gooff::spoton:
These are the facts......on 5.6 psi!!!
  • 2 weeks later...
  • Member For: 20y 4m 27d
Std paper Filter + Std BOV = tiny bit of gobble gobble  :spoton:
Pod + TS BOV = Pssshhhh + very tiny bit of gobble.  :blush:
Pod + no BOV = Loud rattle snake  :blush:
Std paper Filter + no BOV = very tiny bit of rattle snake.  :blink:
Std paper Filter + TS BOV = Loose setting (Pssshhhh...Pssshhhh) tight setting (Pssshhhh)  :blush:
No intake pipe + TS BOV = explosion of psshhh + rattle snake  :msm:  :spoton:
when you used "Pod + no BOV = Loud rattle snake" was the pod directly off the turbo or off the 4' ribbed hose that connects to the airbox?
  • role model
  • Member For: 18y 10m 25d
Hey guys
does the K&N pod and the std BOV does it sound simalir to a VL Turbo??? and with e std BOV did you block of the vacumm hose???
"Pod + no BOV = Loud rattle snake" was straight off the 4inch ribbed hose.
Not sure if it sounds like a vl turbo but since the vl doesnt use a bov I'd assume it sounds similar (the rattle snake that is).
When the std BOV was disconnected I did block the vacuum hose...the bov was still there but since its reverse vented and only for a test I didn't think I would loose much/any boost.
If you blocked the bov, put a pod on the end of the 4 inch ribbed hose, and had 10psi...........you would have a hell of a big rattle snake under the bonnet.
  • role model
aahhaha yer becasue im on std boost and ive block up the vacumm hose on the BOV and sound good but I want it louder ive been told to put a pod and should sound louder is that true?
you wont here bugger all without a pod. The pod is the key!!
