Dillz Three pedals are better then two.. Donating Members 15,637 Member For: 17y 11m 12d Gender: Male Location: Melbourne Posted 17/07/11 09:57 AM Share Posted 17/07/11 09:57 AM Yeah that definitely sounds like it now. Link to comment https://www.fordxr6turbo.com/forum/topic/24608-turbo-flutter-and-blow-off-valves/page/13/#findComment-1123918 Share on other sites More sharing options...
riptide Member 733 Member For: 14y 3m 20d Gender: Male Location: Auckland, New Zealand Posted 18/07/11 06:28 AM Share Posted 18/07/11 06:28 AM Tried a little bit softer spring but it was too soft. Was hard to get on boost with out flooring it to close the BOV. Seems like a touchy operation getting it just right. Is it ok to shorten the hard spring a little by cutting the end off or do I have to keep searching for just the right spring? Link to comment https://www.fordxr6turbo.com/forum/topic/24608-turbo-flutter-and-blow-off-valves/page/13/#findComment-1124210 Share on other sites More sharing options...
Dillz Three pedals are better then two.. Donating Members 15,637 Member For: 17y 11m 12d Gender: Male Location: Melbourne Posted 18/07/11 06:38 AM Share Posted 18/07/11 06:38 AM I don't really know mate, I just put mine on and that was it.What sound are you after? Don't forget the auto will never sound as good as a manual and you hardly ever hear it anyway. Link to comment https://www.fordxr6turbo.com/forum/topic/24608-turbo-flutter-and-blow-off-valves/page/13/#findComment-1124212 Share on other sites More sharing options...
riptide Member 733 Member For: 14y 3m 20d Gender: Male Location: Auckland, New Zealand Posted 18/07/11 07:07 AM Share Posted 18/07/11 07:07 AM I want to get rid of most of the flutter on the easy driving. Not too worried about the rest of it. Probably similar to the way the Bosch one acted would be fine :D Link to comment https://www.fordxr6turbo.com/forum/topic/24608-turbo-flutter-and-blow-off-valves/page/13/#findComment-1124221 Share on other sites More sharing options...
Wenier Donating Members 1,736 Member For: 15y 3m 20d Gender: Male Location: Christchurch, New Zealand Posted 18/07/11 09:46 PM Share Posted 18/07/11 09:46 PM So its only spring changes. You can't adjust the top of the BOV by screwing it in or out to change the spring tension? Link to comment https://www.fordxr6turbo.com/forum/topic/24608-turbo-flutter-and-blow-off-valves/page/13/#findComment-1124394 Share on other sites More sharing options...
riptide Member 733 Member For: 14y 3m 20d Gender: Male Location: Auckland, New Zealand Posted 19/07/11 08:22 AM Share Posted 19/07/11 08:22 AM Not on this one. I could have spent the extra $50 and got the adjustable one...but $50 is a fishing trip...or a couple a dozen piss. I might try squashing the spring down or something to that effect. At least it's holding the power well and coming on good. It's only a matter of time 'till I get pulled over like it is though. Link to comment https://www.fordxr6turbo.com/forum/topic/24608-turbo-flutter-and-blow-off-valves/page/13/#findComment-1124531 Share on other sites More sharing options...
Wenier Donating Members 1,736 Member For: 15y 3m 20d Gender: Male Location: Christchurch, New Zealand Posted 20/07/11 02:29 AM Share Posted 20/07/11 02:29 AM Might get pulled up but over here im pretty sure there is no law against that setup. Link to comment https://www.fordxr6turbo.com/forum/topic/24608-turbo-flutter-and-blow-off-valves/page/13/#findComment-1124712 Share on other sites More sharing options...
riptide Member 733 Member For: 14y 3m 20d Gender: Male Location: Auckland, New Zealand Posted 23/07/11 12:48 AM Share Posted 23/07/11 12:48 AM On 16/07/2011 at 8:37 PM, Dillz said: It's wierd I swear mine runs a tiny bit better with it blocked, even though it shouldn't. I know there's fark all lag with an auto anyway but still.I think you might be onto something. I noticed a performance improvement with the stronger spring in the new BOV over the standard Bosch one. I guess pressure in the plenum isn't required to help close the BOV and the IC and piping are already full of lightly pressurized air waiting for the butterfly to open...The Bosch one was bleeding air off at idle and on light deceleration so this would have stopped line pressure from being maintained I guess... Link to comment https://www.fordxr6turbo.com/forum/topic/24608-turbo-flutter-and-blow-off-valves/page/13/#findComment-1125670 Share on other sites More sharing options...
Dillz Three pedals are better then two.. Donating Members 15,637 Member For: 17y 11m 12d Gender: Male Location: Melbourne Posted 23/07/11 03:26 AM Share Posted 23/07/11 03:26 AM Makes sense. Link to comment https://www.fordxr6turbo.com/forum/topic/24608-turbo-flutter-and-blow-off-valves/page/13/#findComment-1125732 Share on other sites More sharing options...
Dillz Three pedals are better then two.. Donating Members 15,637 Member For: 17y 11m 12d Gender: Male Location: Melbourne Posted 20/08/11 09:11 AM Share Posted 20/08/11 09:11 AM Just curious as to what everyone thinks but if you have blocked your stock bov so it flutters that's not illegal like a vented bov is it? Even though it make a sound? Link to comment https://www.fordxr6turbo.com/forum/topic/24608-turbo-flutter-and-blow-off-valves/page/13/#findComment-1134727 Share on other sites More sharing options...
