Subwoofer Replacement
driftpig01
  • Replies 20
  • Member For: 19y 3m 11d
The box is made out of12mm MDF and has been fibre glass reinforced, it is light enough to lift out in the event of a flat. There is also a panel that covers the woofer so you can put stuff in the boot.
  • Member For: 20y 3d
oooooooo I thought you actually took the tyre out..
Got pics with the panel to cover it?
  • Member For: 20y 4m 20d
Could you put up a pic of the box out of the car please? This looks like exactly what I want to do. Have a sub box without losing bootspace!
Chris :blush:
  • Member For: 22y 1m 5d
Here is a pic of the subwoofer box I knocked up over the weekend. It fits flush with the floor in the boot and sit in the spare tyre well.
That looks great, can we see some more pics and info on the setup??
I am keen to do the same!! :blush:
Sorry about the lateness of my reply had to duck interstate, will take some more photos on the weekend, no I did not cut a hole in the carpet, however did make some small slot at the rear to allow a little more stretch. You will have to turn the spare tyre up the other way and take out the piece of board so the extension where the subwoofer sits inside the tyre. FYI the sub box is about 48l, it has 2 50mm ports which are 78mm long it is tuned to 32Hz and the port have a coefficient less than 0.15 so they don’t whistle. The port size and length will be different for every woofer.
