First Trip To Wsid
fill
  • Member For: 19y 4m 22d
I just thought I would get some opinions on my first 1/4 mile runs in my T.
FYI- I drive a 2004 MKI auto with Edit, 42lb injectors, APS exhaust, Wog intercooler, 2nd typhoon CAI with BMC filter,BOV. My current tune has been done by a shop here in Sydney and is currently pushing 279.1rwkw @12psi of boost.
I removed the spare and ran the tire pressure at 20psi & 18psi for tonight. I stalled to around 2200 the first few runs, 2400 on the third run (a little wheelspin) and 2000 the last. I did a decent burnout before each run.
I was thinking I should be easily into the 12's or at least a 110+ mph but ran the following times/mph.
1st run: 60' 2.209, ET 13.403 @ 107.20
2nd run: 60' 2.170, ET 13.218 @107.27
3rd run: 60' 2.134, ET 13.277 @107.26
4th run: 60' 2.128, ET 13.213@107.78
I will post my dyno and time slips tomorrow.
My question to all is this, what will get me into the 12's? From looking at other peoples times with this kind of power I should be getting way better times/mph.
cheers
  • Replies 67
  • Seriously Flukey Member
  • Member For: 20y 9m 18d
I think you should be running quicker.
For example, the time in my sig was with similiar mods to yourself, other than
my exhaust was stock (just the centre muffler done) and stock cooler.
Not sure what the answer is though :glad:
  • Member For: 18y 11m 29d
mate I reckon u should be making more power than that on 12psi a mates T makes 293rwkw at the wheels on same boost with centre muffler removed phoon cooler bigger injectors and pump and here comes the funny part it does all that with a cracked #1 piston it has run 12.7 with the last owner but on a little less power(apparently) mate get it on dyno again and get it tuned again by a good company..
My 2c
  • Member For: 21y 9m 5d
I'd say on those times you have about 250 atw's...with your mods you should have done better...may pay to run it on an independent dyno or give another tuner a go
If you can get your 60'time down 2/3 tenths you'll be in the 12's also :stirthepot:
  • Mushroom
  • Member For: 20y 7m 24d
You should be getting higher MPH IMHO. Mine ran as high as 114 with 275rwkw's and similar mods and has run a string of 12.0's.
My advice to get better times with your current power (probably around 250 as someone else mentioned) is to get better tyres (MT ET streets), a shift kit and a higher stall. You'll knock a heap off those times.
Just a shift kit and some launch practice will probably see a 12.
  • Member For: 21y 2m 12d
Not sure what the answer is though :stirthepot:
Perhaps some of you melbourne folk can try running at WSID. It appears the track is definiately not delivering the times that calder does, for example.
Why that is could be a number of things. Temperature is certainly one of them, so is track condition.
are you doing the shifting or the box in performance mode?
how hot was it last night?
It was pretty warm last night as it hit 30 degrees in Sydney yesterday.
I let the auto do the shifting for me.
  • Member For: 21y 6m 12d
Not sure what the answer is though :laughing:
But it still doesn't explain the terminal speed being down. :gooff:
Exactly. MPH is low for those mods / power levels
