Turbo Noise
thwart
  • Member For: 18y 10m 17d
Hi I am new to this post so "Hello to everyone!"
My Turbo has a problem under boost; and it seems to be when the engine is colder, it is whistling! I am not sure how to deal with this problem?
Does anyone else get this? Is it normal?
It does not seem to affect the cars performance, but how would I know if it has been slowly doing this over time?
I am reluctant to take it to Ford as they are normally a pain in the posterior.
I have gone to "Ford Service" on several occasions, the last being about 5 warranty issues including a rattle coming from the front right of the car, presumably a loose heat shield or something of the like...Anyway they said they will charge me to find the rattle as they are not covered under warranty! I said it was BS and to go ahead and check the heat shielding....Anyway I went to pick up my car and the service rep said everything was fixed and they found that the right engine mount had failed and they would need to order a part in to fix it.
To make a long story short you have to state the bleeding obvious or you will never get a result. If the turbo is normal I don't want to be out another day or two to have the Service Department tell me they couldn't find it!
If someone has had a similar problem with Turbo Noise please let me know what it may be and what you did to fix or not fix it.
Thanks heaps
Wade
  • Replies 31
  • My engine bay is Bionic
  • Member For: 18y 11m 3d
This is not normal??????????? I always though it was spose to do that otherwise mine is going into Ford first thing Monday morning, cause its been doing it since I bought it last week.
  • Colossal Member
  • Member For: 20y 5m 28d
If the car isnt edited then I'm not overly sure (if your sure its not affecting performance) but it is possible however that the intercooler piping has come loose. Check the hose that goes from the cooler (just near the battery) up to the crossover pipe. This may be not connected fully. Check the obvious first (watch out it gets pretty warm down there).
Otherwise it may just be the sound it's supposed to make? :sleepystuff:
Without having another turbo to compare to, it is pretty hard to gauge. I would suggest that it is a similar sound to what I read in a previous post about the "wheel" compressor or other, touching the turbo case.
I know what a turbo sounds like and my previous car a charade, didn't make this sound, but that's not to say this one doesn't.
I will check the piping and see what that unveils and perhaps get ford to look at it as they listen to them all the time...
...PS in addition, I suppose the clunking in the rear end when starting from a stop is supposed to be there?
wade
  • TEAM BA
  • Member For: 20y 2m 14d
unfortunatly it is a factory extra, search for diff clunk if you want to learn more :tease:
  • Member For: 21y 7m 25d
Guys,
It's hard to call without hearing the noise, however, if:
- the noise can be heard under hard accelaration, then it's probably the normal "whistle" you can hear from a turbo doing its thing.
- the noise is present under any driving conditions, then it may be electrical interference coming through your stereo. MKI's used to have this quite often and FoMoCo does have a fix for it.
  • Site protagonist
  • Member For: 21y 9m 10d
When mines under boost it sounds like a 747 about to take off. :msm: Yours shouldn't be that loud. :tease:
If your anywhere near Chadstone in melbourne send me a PM and I'll have a listen and tell you what I think.
Geea. :msm:
