  • Colossal Member
  • Member For: 20y 9m 27d
Liquid NOS??
What is that??
Oh and I imagine that whatever it is, it wouldnt do sh!t for your car unless you have it tuned to run that fuel
https://www.fordxr6turbo.com/forum/topic/24524-sonico/#findComment-367095
  • Member For: 21y 2m 21d
Sunoco race fuel, it will make power but you will have to swap out your plugs and cat as these fuels contain lead and with foul both,
you will be able to screw heaps more timing in as well as more boost but you will need to retune (edit) to achieve both of these of course
Edited by Chris xr6
https://www.fordxr6turbo.com/forum/topic/24524-sonico/#findComment-367097
  • Member For: 19y 2m 27d
im not really sure but in this months zoom magazine there is an article about there lancer turbo and they drain the 98 ron and refill with sonico 118 ron nos supreme they got it from the guys at pac performance on loan cos they ran out on the dyno.
there is also 2 atricles on 6turbos.
one was a white 320rwkw.
and one full of tech info about there xr6 extreme.
was a great read
https://www.fordxr6turbo.com/forum/topic/24524-sonico/#findComment-367098
its not for me to use I have warranty, I ment for u guys to use.
is it really nos. I mean liquid nitro meth mix or have they mixed nitro with leaded petrol
https://www.fordxr6turbo.com/forum/topic/24524-sonico/#findComment-367099
  • Site protagonist
  • Member For: 22y 1m 8d
<{POST_SNAPBACK}>
I've used C16 which also contains lead. I changed my cat for a cat pipe but left the plugs alone and had no dramas. The only reason I removed the cat was to stop it melting. With C16 we were able to take my car from 330rwkw's with 98ron fuel to 380rwkw's with the C16.
Geea. :thumbsup:
https://www.fordxr6turbo.com/forum/topic/24524-sonico/#findComment-367108
  • Colossal Member
Since NOS is a gas (N2O) it wouldnt be the same thing, it might just be the brand name added to the bottle. I have seen bottles at supercrap auto with "NOS" on them as fuel additives, but I think its simply use of a brand name.
https://www.fordxr6turbo.com/forum/topic/24524-sonico/#findComment-367114
  • Member For: 20y 10m 29d
From the VPW website - who are an Australian retailer for Sonoco fuels.
"Sunoco's highest octane racing fuel was developed specifically for competition engines using nitrous oxide injection systems. Supreme NOS is formulated to achieve a significantly higher specific gravity than other high octane fuels, allowing for maximum fuel flow when used with high volume nitrous oxide systems. The dense nature of this fuel helps guard against lean conditions that can lead to catastrophic engine damage. Due to the high tetraethyl lead (TEL) content, it should not be used in applications utilizing oxygen sensors. Motor Octane 117, Color Light Red, Leaded YES."
The price for a 20 litre drum is $192.55. Unless you had an all out race engine, this fuel would be unwarranted and as stated above contains lead and would be illegal to use anywhere else but at a sanctioned track that has this fuel homologated.
As an aside, I use the Sonoco Supreme Leaded (112 RON) in my dragster with could results. Unfortunately there is no pump fuel available that will handle my engines static compression ratio of 16.3:1 :thumbsup:
https://www.fordxr6turbo.com/forum/topic/24524-sonico/#findComment-367115
thanks for the info 4 runner.
im going to see your mate at campbelltown mc shop on sat to get my helmet will mention u so he knows u are putting the word out.
https://www.fordxr6turbo.com/forum/topic/24524-sonico/#findComment-367120
