xr6tee Member 19 Member For: 19y 8m 13d Location: Melbourne (alias Mexico) Posted 31/03/06 08:20 AM Share Posted 31/03/06 08:20 AM Hi guys,had a call from mate of mine who had his Falcon EA S in service recently. ...well, it used to be mine actually before I bought the XR6T. I have always changed oil and filters religiously and the car has always run great (it has close to 250K on the clock)He took it to garage as he noticed the valves have been making ticking noises and he was told that this could be due to the oil filter being fitted. Apparently he should have been fitting oil filter that has the built-in valve to stop the oil flowing out of it once the engine stops so when you start the engine when cold, the oil does not have to be pumped back into the filter and thus it's kinder on the engine when cold. I suppose that makes sense.Now, how does that related to XR6T? As most of you probably know, Ford has been using the venerable Z9 filter for yonk years and the same filter is used in the XR6Ts......in fact in any 6cyl Falcon for as long as I can remember. For those in the know, my question is:Are there two different types of the Z9 filter? (ie one with the valve fitted and the other without one?). If this is the case, then that could posibly justify the price differences between various brands on the market. One would hope that the highper priced Z9s are fitted with this so called oil retaining valve while the cheaper ones aren't.I would hate (unwittingly) to hurt my 'pride and joy' by fitting an inferior oil filter but by the same token, I don't want to pay more if all the Z9 filters are exactly the same in this regard. I hope that someone on the forum can comment on this and clears this up, not just for me but for many XR6T owners who may be concerned just like I am. Link to comment https://www.fordxr6turbo.com/forum/topic/24435-not-all-oil-filters-are-equal/ Share on other sites More sharing options...
Guest Guests Posted 31/03/06 09:21 AM Share Posted 31/03/06 09:21 AM Don't know much about it oil filters, but from the begining Ive been fitting K&N oil filters to my donk Im happy with them so far. Link to comment https://www.fordxr6turbo.com/forum/topic/24435-not-all-oil-filters-are-equal/#findComment-365908 Share on other sites More sharing options...
bloosted Cruise Control 1,383 Member For: 19y 6m 28d Gender: Male Location: Adelaide Posted 31/03/06 09:41 AM Share Posted 31/03/06 09:41 AM I used to have an xf that rattled real bad when cold and that was the cause as well,changed to fleetguard oil filter and fixed it straight up can only be good Link to comment https://www.fordxr6turbo.com/forum/topic/24435-not-all-oil-filters-are-equal/#findComment-365914 Share on other sites More sharing options...
xr6tee Member 19 Member For: 19y 8m 13d Location: Melbourne (alias Mexico) Posted 31/03/06 11:13 PM Author Share Posted 31/03/06 11:13 PM Thanks for the replies so far. It looks like the more expensive oil filters are justified from what has been said so far. Link to comment https://www.fordxr6turbo.com/forum/topic/24435-not-all-oil-filters-are-equal/#findComment-366063 Share on other sites More sharing options...
Goobz Member 746 Member For: 20y 8m 22d Location: Sutherland Shire, Sydney Posted 31/03/06 11:20 PM Share Posted 31/03/06 11:20 PM It usually says on the box if it has a check valve fitted. The Ryco one I bought from Repco had one in it...Chris Link to comment https://www.fordxr6turbo.com/forum/topic/24435-not-all-oil-filters-are-equal/#findComment-366066 Share on other sites More sharing options...
Adam Here since the start... Lifetime Members 10,282 Member For: 22y 2m 7d Gender: Male Location: Victoria Posted 31/03/06 11:27 PM Share Posted 31/03/06 11:27 PM I just use the genuine Ford AFL1 filter.For some reason I think it would be suited to the car. Link to comment https://www.fordxr6turbo.com/forum/topic/24435-not-all-oil-filters-are-equal/#findComment-366069 Share on other sites More sharing options...
JimmyXR6T04 Member 1,299 Member For: 20y 13d Location: Canberra Posted 01/04/06 12:09 AM Share Posted 01/04/06 12:09 AM I was told by a mate with some good knowledge and experience that the ryco Z9 filter is basically identical to the ford one. So I usually buy them from repco. Haven't had any problems, and I change my oil every 3500-5000kms. I've been using the penzoil GT oil, and again had no issues! Link to comment https://www.fordxr6turbo.com/forum/topic/24435-not-all-oil-filters-are-equal/#findComment-366082 Share on other sites More sharing options...
JBomb3000 Donating Members 875 Member For: 19y 7m 13d Gender: Male Location: Victoria Posted 01/04/06 01:21 AM Share Posted 01/04/06 01:21 AM I stuck with the ford filter to avoid any potential warranty problems. Link to comment https://www.fordxr6turbo.com/forum/topic/24435-not-all-oil-filters-are-equal/#findComment-366095 Share on other sites More sharing options...
HellionXR6T I'm Back!! Thats right, long over due! :) Lifetime Members 4,348 Member For: 22y 7m 29d Gender: Male Location: West Brisbane Posted 01/04/06 02:00 AM Share Posted 01/04/06 02:00 AM From what I can see and from what some of my mates that are mechanics and Ford enthusiasts as well, it's identical to the Z9 but I did the same, used the "Ford" oil filter. Link to comment https://www.fordxr6turbo.com/forum/topic/24435-not-all-oil-filters-are-equal/#findComment-366104 Share on other sites More sharing options...
Falchoon I see red Member 5,758 Member For: 22y 6m 17d Location: nowhere in particular Posted 01/04/06 02:25 AM Share Posted 01/04/06 02:25 AM I used to have an xf that rattled real bad when cold and that was the cause as well,changed to fleetguard oil filter and fixed it straight up can only be good<{POST_SNAPBACK}>My XF does that too and I've got some cheap arse generic filter on it too - matches the oil! I'll change the filter to a Ryco and put some better oil in and see if it makes a difference.Pretty sure the Ford AFL1 oil filter and the Ryco Z9 are both made by Ryco. They have recently changed to manufacturing in Thailand. Link to comment https://www.fordxr6turbo.com/forum/topic/24435-not-all-oil-filters-are-equal/#findComment-366111 Share on other sites More sharing options...
