PSI40L Member 175 Member For: 22y 2m 8d Posted 20/01/03 02:26 AM Share Posted 20/01/03 02:26 AM picked the car last week from service they fixed the bonnet lever,engine light problem,crocky horns but went through the car and found a long scratch on the front bumper ran in side back to service showed the manenger in my utter frustration and he said "chris there is no problem we'll fix it ...anyway got home popped the bonnet to check all myfluid levels and to concern found some melted rubber on the tensioner pulley on the fan belt..What I notced it is been wearing the outside of the belt..the rubber is on top of the tensioner and a bit on the side of the motor so one of the other pulleys must be misaligned ...Here we go again...has anyone else noticed such a problem Link to comment Share on other sites More sharing options...
CJF077 The Noble Leader Administrator 4,786 Member For: 22y 4m 14d Gender: Male Location: Sydney Australia Posted 20/01/03 09:30 PM Share Posted 20/01/03 09:30 PM Whats the engine light problem and horn? Link to comment Share on other sites More sharing options...
Ninka Donating Members 1,850 Member For: 22y 2m 2d Gender: Male Location: Perth, WA Posted 21/01/03 01:48 PM Share Posted 21/01/03 01:48 PM See thread in Workshop/Engine Light, STILL NO CARAs far as rubbing the fan belt, I can only see a little bit of rubber on top of the belt adjuster. Does not look like something to worry over!Maybe yours is excessive? Link to comment Share on other sites More sharing options...
ASNU Member 261 Member For: 22y 1m Location: Brooklyn Posted 12/08/03 10:50 PM Share Posted 12/08/03 10:50 PM My car was at the dealers testerday getting the dreaded water pump oring fixed and the belt replaced as it was starting to get noisy first thing in the morning and they carried out a modification to eliminate the black belt shavings falling on to the tensioner.The problem they said was on the pully on top of the tensioner the outer edges to guide the belt has a very rough surfuce cutting into the belt.All they did was just have the motor running and put some very fine wet and dry sandpaper on the outer edge to take off the high spots thus eliminating the wear.Started first thing this morning and no more noise but will have to wait a week or so to see if anymore belt is been left behind.I am sure I dont have to highlight to anyone attempting this at home to be very careful with your hands. Link to comment Share on other sites More sharing options...
Dagabond Bored Member Administrator 35,722 Member For: 22y 3m 12d Gender: Male Location: Dé·jà vu Posted 13/08/03 12:53 AM Share Posted 13/08/03 12:53 AM the belt replaced as it was starting to get noisy first thing in the morningWhat was the noise ASNU?Was it like a ticking sound only when cold? Link to comment Share on other sites More sharing options...
Ditto Member 10 Member For: 21y 7m 16d Location: Melbourne - South eastern Posted 13/08/03 01:00 AM Share Posted 13/08/03 01:00 AM I've got the same problem - squeeling belt and shavings every whereHopefully its been repaired today with the leaking coolant and shuddering brakes.Must be common.Did they replace the belt, as the belt has worn. Link to comment Share on other sites More sharing options...
Trumpy What's happening? Lifetime Members 1,605 Member For: 22y 2m 22d Gender: Male Location: Steel City, NSW Posted 13/08/03 01:39 AM Share Posted 13/08/03 01:39 AM Mine has almost 20K km on it now, so no more rubber shavings in the engine bay.What I do have is a bad belt squeal whenever it is cold (for about 15 to 20 minutes). Have had the dealer look at it several times now, when they said they cleaned and tightened the belt. Squeal came back within a thousand of so.Was in on Monday demanding a new belt as the squeal keeps returning, and they have told me that its the alternator bearings and they have ordered in a new alternator. We'll see how it goes next week.... Link to comment Share on other sites More sharing options...
Dagabond Bored Member Administrator 35,722 Member For: 22y 3m 12d Gender: Male Location: Dé·jà vu Posted 13/08/03 01:51 AM Share Posted 13/08/03 01:51 AM they have told me that its the alternator bearings and they have ordered in a new alternator.That's the reason they gave me and why I asked the question Trumpy, they said the same to me when I had mine back for the third time but instead of replacing the alternator they just gave it a blow out with an airgun. It has been fine since, with about 5k on the clock. Link to comment Share on other sites More sharing options...
ASNU Member 261 Member For: 22y 1m Location: Brooklyn Posted 13/08/03 02:28 AM Share Posted 13/08/03 02:28 AM Exactly.A ticking sound that went away when the motor warmed up. Link to comment Share on other sites More sharing options...
ASNU Member 261 Member For: 22y 1m Location: Brooklyn Posted 13/08/03 02:33 AM Share Posted 13/08/03 02:33 AM I've got the same problem - squeeling belt and shavings every whereHopefully its been repaired today with the leaking coolant and shuddering brakes.Must be common.Did they replace the belt, as the belt has worn. They did replace the belt as I dont think think it is exceptable in this day and age that this should happen plus it was starting to make a mess on my alternater plus tensioner.They said it had no harmfull effects on the belt but I am not quite sure of that.Rubber shavings everywhere cannot mean good things for the belt. Link to comment Share on other sites More sharing options...
