RHR BOOST Moderating Team 5,698 Member For: 21y 8m 25d Gender: Male Location: Southern Highlands NSW Posted 21/03/08 01:41 AM Share Posted 21/03/08 01:41 AM I was filling up the work car the other day at Mobil and read a bit of info on their E10. They said its a higher octain than their stanard unleaded. Interesting.I use United fuel all the time their plus 95 and their boost 98. I have never had a problem on it at all. I has never pinged and I have a custom tune Link to comment https://www.fordxr6turbo.com/forum/topic/24250-e10/page/4/#findComment-648516 Share on other sites More sharing options...
XRPete Member 673 Member For: 17y 8m 20d Gender: Male Location: Here Posted 21/03/08 09:23 AM Share Posted 21/03/08 09:23 AM off topic here a litttle but I've noticed Shell have a new V-power 100 octane and e-10 blended.Any views on this???????? Link to comment https://www.fordxr6turbo.com/forum/topic/24250-e10/page/4/#findComment-648713 Share on other sites More sharing options...
Trough Lolly Member 4,349 Member For: 20y 8m 22d Gender: Male Location: Mildura Posted 22/03/08 04:03 AM Share Posted 22/03/08 04:03 AM I run Boost98 in my ute 90% of the time and I have no issues with it!when I put normal 98's back in such as BP and Mobil I dont notice much of a difference, IF ANYTHING it actually goes a bee's dick harder on the United 98. Link to comment https://www.fordxr6turbo.com/forum/topic/24250-e10/page/4/#findComment-649011 Share on other sites More sharing options...
FastR1Red Member 360 Member For: 20y 29d Gender: Male Location: Mt Waverley Posted 22/03/08 06:55 AM Share Posted 22/03/08 06:55 AM Doesn't matter what octane it is, E10 simply means the fuel contains up to 10% Ethanol.So if it's a 91RON fuel and marked E10 it'll have 10% Ethanol. ie, Boost 98 is marked E10, so it contains up to 10% Ethanol and is a 98 octane. Some fuels do, some don't. United increase the octane rating of their fuel with ethanol, so with thier 95 octane for instance, it would only be say 90 or 93 or so and with their addition of ethanol in the mix, they get it up to 95. Hope that makes sense???? Link to comment https://www.fordxr6turbo.com/forum/topic/24250-e10/page/4/#findComment-649071 Share on other sites More sharing options...
straughsberry Donating Members 1,846 Member For: 17y 9m 13d Gender: Male Location: Broady, Melbourne Posted 22/03/08 07:40 AM Share Posted 22/03/08 07:40 AM xrdreaming said: Tom I am pretty sure that most people who run E10 use the Boost 98 from united.I just tried a tank of the Boost 98. Seemed OK but it delievered poorer fuel economy and I did get ping under WOT. Having said that I did just get a tune on a hot 35c day, and it was a cold night when I got the ping so it may not be the fuel. Link to comment https://www.fordxr6turbo.com/forum/topic/24250-e10/page/4/#findComment-649085 Share on other sites More sharing options...
ColinT Donating Members 372 Member For: 20y 3m 29d Posted 03/09/09 09:31 PM Share Posted 03/09/09 09:31 PM Could not believe the argument I got into today.My BA XR6 Turbo I run on RON98.The argument I had the today was from a friend who runs his FG XR6 Turbo only on E10. His argument is that his engine it rated at 270KW and mine only at 240KW. To that I suggested that on E10 he would be lucky to make 240KW.I can't see why on earth you would buy a Turbo just so as to run it on E10.But Ford do mention in the manual that it will run on 91 or higher (at what power).Anyone care to guess what sort of KW loss there would be on E10? Link to comment https://www.fordxr6turbo.com/forum/topic/24250-e10/page/4/#findComment-929074 Share on other sites More sharing options...
ETM Member 1,194 Member For: 18y 2m 17d Gender: Male Location: syd south Posted 03/09/09 09:48 PM Share Posted 03/09/09 09:48 PM In theory you are both correct, ethanol is a wonderful fuel with a high octane rating and is often used to bump up the octane rating of a fuel but a 91 ron fuel, containing ethanol or not, is still a 91 ron fuel. If they took regular 91 ron fuel and then added ethanol it would probably go close to being an equal match but they are using fuel with less than 91 ron and using the ethanol to bump up the octane rating to 91 ron. The ethanol will have a good effect on the engine but 91 is 91 no matter which way you look at it.Your mate is correct in theory but wrong in the real world.You are the winner please never let him forget it Link to comment https://www.fordxr6turbo.com/forum/topic/24250-e10/page/4/#findComment-929080 Share on other sites More sharing options...
dashturbo Donating Members 280 Member For: 16y 9m 23d Gender: Male Location: Watsonia Posted 04/09/09 05:52 AM Share Posted 04/09/09 05:52 AM Ethanol is available in different RON, not 91 in Victoria though, we did some E10 testing and found..What RON?The Fuel we used in our test was Shell E10, Shell indicates that this is a 94 RON Fuel. Liberty Fuels also specify a 94 RON Rating whilst United indicate that their E10 is 95 RON. 98 Ron E10 is also available but I cant recall where, and shell 100 RON contains ethanol. Ron doesn't increase power anyway, it allows for a different ignition circumstances which mean you can make an engine more efficient with a higher RON (generally)Energy ContentWe found that E10 fuel had a 3.4% less energy than pure petrol. so you would expect 3.4% less energy and power in a perfect world but there are too many factors that come into play to draw that conclusion with any accuracy.I reckon that its silly to run it on E10 but there is nothing to say he shouldn't... except for the government durability testing, that is available somewhere on the web, it wears out engines alot quicker than normal petrol, mainly because it burns hotter and seems to damage exhaust valves, rings, and catalytic converters, turbos I haven't seen tests for. Link to comment https://www.fordxr6turbo.com/forum/topic/24250-e10/page/4/#findComment-929250 Share on other sites More sharing options...
PAH Donating Members 361 Member For: 16y 4m 12d Gender: Male Posted 08/01/10 10:15 AM Share Posted 08/01/10 10:15 AM Hi Guys,The lower energy content of E10 means that you will USE MORE FUEL. Given that its cheaper price is the main reason people buy E10, the fact that you WILL burn more fuel reduces the price benefit at the petrol pumps. The claim that it's not as kind to engines also worries me. You've probably noticed that Oil Co's have jacked up the price of 98 RON to around 20 cpl more than 91 RON. With high output engines such as the XR6T, the 3.0L SIDI and the rumoured 3 cyl turbo Falcon (all cars that will use less high octane fuel than 91 RON fuel), the Oil Co's are working against the Fed Govt's carbon reduction agenda. 98 RON is bought by enthusiasts. Would the Oil Co's take advantage of that? You can answer that question yourselves. The the dirty bathplugs push too much futher, it will be cheaper to buy a bottle of octane booster.PAH Link to comment https://www.fordxr6turbo.com/forum/topic/24250-e10/page/4/#findComment-969175 Share on other sites More sharing options...
ratter Member 6,793 Member For: 19y 3d Gender: Male Location: @ my laptop Posted 08/01/10 11:47 AM Share Posted 08/01/10 11:47 AM On 08/01/2010 at 10:15 AM, PAH said: .............. it will be cheaper to buy a bottle of octane booster.PAHOr convert to Liquid gas injection Link to comment https://www.fordxr6turbo.com/forum/topic/24250-e10/page/4/#findComment-969206 Share on other sites More sharing options...
