sutty Mushroom Donating Members 799 Member For: 20y 11m 15d Gender: Male Location: THORNLANDS, QLD Posted 20/03/06 11:53 AM Share Posted 20/03/06 11:53 AM Quote How can a lot of other people get much more than 240 with alot less and standard cat then???Im interested to know as im going down a similar pathDaveAs someone else mentioned earlier, there is likely another problem here. If Rob's car is pinging, I seriously doubt it has anything to do with the tune as all the FIST tunes I've seen (around are on the rich side - never lean. Maybe the pump is failing??? I'm no expert - he'll need to take it back to get checked.Rob, did the injectors go in when the tune was done or did someone else fit them?I feel for ya mate. I've had my fair share of prob's getting to where I am now - including my car being of the road atm with a busted convertor - but IMO the end result has been worth it. I've now got one of the quickest BA's in QLD and lovin' every minute of it - when it's on the road. Link to comment https://www.fordxr6turbo.com/forum/topic/24165-pinging-pinging-and-more-pinging/page/2/#findComment-361791 Share on other sites More sharing options...
urslow Resident golf buggy drift champion Donating Members 815 Member For: 19y 6m 11d Location: Lismore NSW Posted 20/03/06 11:57 AM Share Posted 20/03/06 11:57 AM F6 UTE said: I doubt the cat is the restriction at that power level. Simon himself has extracted 271rwkw from an xr6t with only 968's, nothing else, so case in point. I fail to see why he has now changed his modification criteria??300rwkw untill cat replacement I thought was the general concesus??Me too... 240s along way from 300 even 270..Dave Link to comment https://www.fordxr6turbo.com/forum/topic/24165-pinging-pinging-and-more-pinging/page/2/#findComment-361794 Share on other sites More sharing options...
RAPHOON Donating Members 1,776 Member For: 21y 10m 3d Posted 20/03/06 12:00 PM Share Posted 20/03/06 12:00 PM Robit28 said: Well, I had the car tuned at FIST again and they managed to get 241rwkw out of it. Well, it lasted all of 1 day and now as soon as I put my foot down and the car reaches the 4000rpm line, the engine starts to ping its *beep* off! WTF????My mods are as follows:K&N Filter2nd CAIEditCentre Muffler Removal968 InjectorsValve SpringsShift KitI am only sitting at 241rwkw, I would have thought I would be fine at this stage.Do I need to have it retuned? Do I sell it? I had better luck with my Hyundai!Any suggestions would help.Rob.Sorry to hear that you're having issues. The first port of call should be to take the car back and eliminate all the factors which may be causing the problem.This could be several things, including the tune but get it checked ASAP.For instance, have you fuelled the car up since then? Link to comment https://www.fordxr6turbo.com/forum/topic/24165-pinging-pinging-and-more-pinging/page/2/#findComment-361796 Share on other sites More sharing options...
Romulus Donating Members 1,279 Member For: 20y 3m 26d Location: Perth Posted 20/03/06 12:05 PM Share Posted 20/03/06 12:05 PM Stock BA MkII manuals are getting 260-270rwkw with a tune only, stock exhaust and injectors. From memory I achieved 285-290rwkw with the stock cat with bigger injectors and intercooler.Do you have any dyno sheets you can show? Link to comment https://www.fordxr6turbo.com/forum/topic/24165-pinging-pinging-and-more-pinging/page/2/#findComment-361798 Share on other sites More sharing options...
sutty Mushroom Donating Members 799 Member For: 20y 11m 15d Gender: Male Location: THORNLANDS, QLD Posted 20/03/06 12:08 PM Share Posted 20/03/06 12:08 PM F6 UTE said: I doubt the cat is the restriction at that power level. Simon himself has extracted 271rwkw from an xr6t with only 968's, nothing else, so case in point. I fail to see why he has now changed his modification criteria??300rwkw untill cat replacement I thought was the general concesus??When I started doing mods a bit over 2 years ago, everyone was saying change the cat first as it was only good for about 250-260. I stand corrected - obviously times have changed. Are there really "heaps" of guys with AUTO's running over 260 with the std cat? Stick your hands up. Link to comment https://www.fordxr6turbo.com/forum/topic/24165-pinging-pinging-and-more-pinging/page/2/#findComment-361800 Share on other sites More sharing options...
F6 UTE - Track Bound EVO III - Member 3,367 Member For: 20y 4m 14d Gender: Male Location: Strapped in and holding on Posted 20/03/06 12:08 PM Share Posted 20/03/06 12:08 PM urslow said: F6 UTE said: I doubt the cat is the restriction at that power level. Simon himself has extracted 271rwkw from an xr6t with only 968's, nothing else, so case in point. I fail to see why he has now changed his modification criteria??300rwkw untill cat replacement I thought was the general concesus??<{POST_SNAPBACK}>Me too... 240s along way from 300 even 270..Dave<{POST_SNAPBACK}>Also, he mentioned at the time, lifters were the limmiting factor. These have been done. Link to comment https://www.fordxr6turbo.com/forum/topic/24165-pinging-pinging-and-more-pinging/page/2/#findComment-361801 Share on other sites More sharing options...
Xtreme F6 Team Xtreme Donating Members 1,680 Member For: 20y 2m 21d Gender: Male Location: Perth Posted 20/03/06 12:13 PM Share Posted 20/03/06 12:13 PM F6 UTE said: I doubt the cat is the restriction at that power level. Simon himself has extracted 271rwkw from an xr6t with only 968's, nothing else, so case in point. I fail to see why he has now changed his modification criteria??300rwkw untill cat replacement I thought was the general concesus??yer but that was a manual dude, autos will always fall around 20 rwkw less. Link to comment https://www.fordxr6turbo.com/forum/topic/24165-pinging-pinging-and-more-pinging/page/2/#findComment-361802 Share on other sites More sharing options...
Paradoxx Colossal Member Member 5,049 Member For: 20y 8m 6d Gender: Male Location: Perth, WA Posted 20/03/06 12:14 PM Share Posted 20/03/06 12:14 PM Sounds to me like the tuner dude... Link to comment https://www.fordxr6turbo.com/forum/topic/24165-pinging-pinging-and-more-pinging/page/2/#findComment-361804 Share on other sites More sharing options...
Xtreme F6 Team Xtreme Donating Members 1,680 Member For: 20y 2m 21d Gender: Male Location: Perth Posted 20/03/06 12:18 PM Share Posted 20/03/06 12:18 PM The highest I have ever gotton from an XR is 271 with stock cat, the highest from an F6 is 285 with stock cat. Never have I said 300 rwkw's will be achievable with a stock cat. Mels car wouldnt go over 252 rwkw's with the stock cat.I have made 350 rwkw's with a stock exhaust but cat and dump mod on my F6. Link to comment https://www.fordxr6turbo.com/forum/topic/24165-pinging-pinging-and-more-pinging/page/2/#findComment-361806 Share on other sites More sharing options...
urslow Resident golf buggy drift champion Donating Members 815 Member For: 19y 6m 11d Location: Lismore NSW Posted 20/03/06 12:20 PM Share Posted 20/03/06 12:20 PM XXXR6T said: Sounds to me like the tuner dude...Finally... Link to comment https://www.fordxr6turbo.com/forum/topic/24165-pinging-pinging-and-more-pinging/page/2/#findComment-361808 Share on other sites More sharing options...
