How To Remove Icc Cover?
FPRXR-6
  • Member For: 22y 17d
Hi, I'm trying to remove the ICC cover but I'm having a hard time removing it.
I've removed the auto surround and removed all the screws around the headunit but it still doesn't want to come out.
Can someone help please?
  • Member For: 19y 2m 28d
once you get the bottom 4 bolts off you need to remove the tissue box holder.
once this is out you unplug the 4 connectors under the ICC starting from the passengers side first (or disconnect the battery before you start).
finally remove the screw at the top that's under the clock/gauges/plastic panel and the ICC will then slide out.
once its out you need to reset the plug at the back where the ICC plugs into before you slide it back in.
have fun and remember to be careful with the ICC as she can fall to pieces if you shake or drop it when its out of the car :spoton:
