jonom Member 96 Member For: 19y 6m 17d Location: South East Suburbs Posted 16/03/06 10:14 PM Share Posted 16/03/06 10:14 PM Guys,just a quick question, if you had an xr6t auto and all you did was CAI and edit, would you need1. extra or larger oil cooler?2. extra or larger trans cooler?3. valve springs?If you were to add the above mods would it be alot more reliable or just a waste of money?Thanks in advance One more quick question I've heard that if you remove one of the mufflers from the exhaust you can pick up a few extra KW's but is there a downside to doing this? does the exhaust become alot louder and does it drone? Link to comment https://www.fordxr6turbo.com/forum/topic/24110-xr6t-mods/ Share on other sites More sharing options...
Adam Here since the start... Lifetime Members 10,282 Member For: 22y 9d Gender: Male Location: Victoria Posted 16/03/06 11:08 PM Share Posted 16/03/06 11:08 PM Trans cooler is a good idea and if you like the track work then the oil cooler wouldn't hurt either.Valve springs are not required at that level.I've heard mixed reports about the centre muffler, some say it works and others don't. Link to comment https://www.fordxr6turbo.com/forum/topic/24110-xr6t-mods/#findComment-360568 Share on other sites More sharing options...
xrdreaming Lifetime Members 1,693 Member For: 22y 3m 5d Gender: Male Location: Melbourne Posted 16/03/06 11:36 PM Share Posted 16/03/06 11:36 PM Of the list you mentioned mate the trans cooler is a must as if things get too hot in the box you will glaze the bands and need a rebuild, it really is good insurance. Link to comment https://www.fordxr6turbo.com/forum/topic/24110-xr6t-mods/#findComment-360584 Share on other sites More sharing options...
veczar Gold Platinum Member Member 1,081 Member For: 20y 10m 8d Gender: Male Location: Victoria Posted 17/03/06 12:32 AM Share Posted 17/03/06 12:32 AM Correct, no valve spring are needed at that level. I have JB's center muffler (or lack of) and it does give a bit more flow to the edit/chiped T, however the primary reason most do this mod is for the audio enhancment. Personally I have done it to give the exhaust system a bit more flow and a 'tougher' sound as a interem mod until I get a full on performance enhancing exhaust.I don't know the exact numbers but ive seen from 5 to 10 rwkw's (with ecu mods) being thrown around the forums. Someone whos done dyno tests please clarify... Link to comment https://www.fordxr6turbo.com/forum/topic/24110-xr6t-mods/#findComment-360609 Share on other sites More sharing options...
Dr Z Member 378 Member For: 21y 2m 13d Posted 17/03/06 12:39 AM Share Posted 17/03/06 12:39 AM Transmission oil cooler as soon as possible with that tune. Link to comment https://www.fordxr6turbo.com/forum/topic/24110-xr6t-mods/#findComment-360615 Share on other sites More sharing options...
Paradoxx Colossal Member Member 5,049 Member For: 20y 8m 10d Gender: Male Location: Perth, WA Posted 17/03/06 01:02 AM Share Posted 17/03/06 01:02 AM Valve springs seems to be a bit of an iffy subject I think. I know that with the generic capa 10psi tune I am having valve spring issues but it seems to be only in certain instances (when the engine is a bit cold and high revs). I have been told a Cat replacement will help this situation if not fix it completely. I am considering this as well as a centre muffler removal (2 hotdogs) for the sound... and some twin pipes for looks. Link to comment https://www.fordxr6turbo.com/forum/topic/24110-xr6t-mods/#findComment-360623 Share on other sites More sharing options...
jonom Member 96 Member For: 19y 6m 17d Location: South East Suburbs Posted 17/03/06 01:08 AM Author Share Posted 17/03/06 01:08 AM Thanks guys much appreciated.By about mid year or abit after I will be looking at buying a car. The options are VY SS or an XR6t. I have been reading these forums for a long time and seems value for money / bang for your buck the xr6t and SS are very similar still not sure which path to take though.Thanks again.Cheers Link to comment https://www.fordxr6turbo.com/forum/topic/24110-xr6t-mods/#findComment-360626 Share on other sites More sharing options...
Paradoxx Colossal Member Member 5,049 Member For: 20y 8m 10d Gender: Male Location: Perth, WA Posted 17/03/06 01:10 AM Share Posted 17/03/06 01:10 AM That one's easy... you have come to the right place Link to comment https://www.fordxr6turbo.com/forum/topic/24110-xr6t-mods/#findComment-360627 Share on other sites More sharing options...
jordak Member 1,226 Member For: 20y 10m 25d Posted 17/03/06 01:20 AM Share Posted 17/03/06 01:20 AM XXXR6T said: Valve springs seems to be a bit of an iffy subject I think. I know that with the generic capa 10psi tune I am having valve spring issues but it seems to be only in certain instances (when the engine is a bit cold and high revs). I have been told a Cat replacement will help this situation if not fix it completely. I am considering this as well as a centre muffler removal (2 hotdogs) for the sound... and some twin pipes for looks.<{POST_SNAPBACK}>One thing to consider Steve, if you do something about the cat then you will need a custom tune. And that's where the mod snowball will start gaining momentum Better flowing exhaust =more boost=more fuel (injectors) = trans / clutch mods = $$$$$$ Link to comment https://www.fordxr6turbo.com/forum/topic/24110-xr6t-mods/#findComment-360633 Share on other sites More sharing options...
dswiders Member 398 Member For: 21y 5m 9d Gender: Male Location: Boronia, Vic Posted 17/03/06 01:41 AM Share Posted 17/03/06 01:41 AM Why not try driving both, firstly try the SS then immediately after, try the XR6T. I then bet you go for the XR6T. ( wager anyone ? )Which ever one you choose, just make sure its the right one for you otherwise it will cost you to change.I can hear it now.... What was that ? ( as the XR6T passes )....wish I bought the turbo Link to comment https://www.fordxr6turbo.com/forum/topic/24110-xr6t-mods/#findComment-360647 Share on other sites More sharing options...
