  • Member For: 19y 10m 23d
  turb06 said:
when you say treated planetary gears in the gearbox, what exactly gets done to them??  I will be needing some gearbox work before I go searching for more power.
Dazza.
Im pretty sure the planetary gears are taken out, and re-tempered so the metal is not as brittle. A few people (Inc myself) have broken or chipped the ends off the teeth on the planetaries, so this is something Kewish have done to eliminate the problem.
By softening the temper of the gears slightly it makes them a little pliable, allowing them to flex instead of just chipping ofr snapping off.
that's why Kewish are not the cheapest, but do a complete job.
  • Replies 27
  • Wanabe mechanical engineer
  • Member For: 20y 7m 12d
  Dannopower said:
Dazza.
Well if they are treating the gears like I think they are, then it also makes them able to withsand quite alot more outright force as well. Inder compression and sheering forces the gear itself is alot stronger...
But this is assuming they are doing a full heat treatment and blast....
I say they would have to be..
Guest xrtwpn
  • Guests
  saleen said:
  SavageD said:
  xrtwpn said:
More big power figures but never any go
Why is this ??
Wonder how long it will take until Brian or Adam pull this post down
<{POST_SNAPBACK}>
Sorry what are you on about exactly (serious question)?
I notice in your sig you're having a crack at the XR6T vs your senator too. To each his own, but I have one Q for ya - if you've got yer knickers in such a twist, why bother posting at all?
<{POST_SNAPBACK}>
Don't worry savage. He had to gut his car, add Nitrous and count on a chilli Victorian night to achieve that (only just) 9 second pass. :spoton:
<{POST_SNAPBACK}>
No NOS on the car check your facts first :msm: a few of the xr6 turbo guys looked over the car and it is still the only xr6 turbo to do it with only 430 to 440rwkw
  • Member For: 21y 10m
Why is this ??
<{POST_SNAPBACK}>
Hi Adam,
Has this car been down the strip ?? I've read through the entire thread but no mention of times.
Robbie.
  • Member For: 21y 10d
For the Typhoon, I was told 270-290rwkw. Doesn't need the heavy duty valve springs either for the stage 1 or 2. Check out the Nizpro forum.
http://forums.nizpro.com.au/phpbb/
