Guest Guests Posted 08/03/06 03:19 AM Share Posted 08/03/06 03:19 AM Good afternoon,Hopefully the answer is as simple as the question sounds, more so out of curiosity but should it be achievable without too many headaches then I'd consider having it done.For those out there that have an idea as to what needs to be considered in implementing a switch, to allow input from the Unichip one minute and should there need be a reason to run the vehicle in a 'factory form' Can this be done?Regards,Darren Link to comment https://www.fordxr6turbo.com/forum/topic/23900-unichip-the-flick-of-a-switch/ Share on other sites More sharing options...
ms700 Moderating Team 10,170 Member For: 22y 3m 12d Gender: Male Location: Sydney Posted 08/03/06 03:22 AM Share Posted 08/03/06 03:22 AM No I believe it can't be done. Link to comment https://www.fordxr6turbo.com/forum/topic/23900-unichip-the-flick-of-a-switch/#findComment-357564 Share on other sites More sharing options...
xlr8ed Phantom lives Member 1,417 Member For: 21y 22d Gender: Male Location: who knows Posted 08/03/06 04:04 AM Share Posted 08/03/06 04:04 AM Link to comment https://www.fordxr6turbo.com/forum/topic/23900-unichip-the-flick-of-a-switch/#findComment-357572 Share on other sites More sharing options...
Eugene Member 670 Member For: 20y 7m 27d Gender: Male Location: Newcastle NSW Posted 08/03/06 05:18 AM Share Posted 08/03/06 05:18 AM DARREN said: Good afternoon,Hopefully the answer is as simple as the question sounds, more so out of curiosity but should it be achievable without too many headaches then I'd consider having it done.For those out there that have an idea as to what needs to be considered in implementing a switch, to allow input from the Unichip one minute and should there need be a reason to run the vehicle in a 'factory form' Can this be done?Regards,Darren<{POST_SNAPBACK}>It could be done, it would need to be through a bank of relays to control it as there are about 16 wires that are use with most of the piggies.it would not be too hard, but why do it? for instant flick a switch high power tune? get an xede, it can be done easy as with it?I am saying it can be done, but I would need a wiring diagram / install instructions for the unichip, and no it wont be plug in if you are serious, give me a PM. Link to comment https://www.fordxr6turbo.com/forum/topic/23900-unichip-the-flick-of-a-switch/#findComment-357612 Share on other sites More sharing options...
TBO240 Member 628 Member For: 21y 9m 8d Gender: Male Location: Geelong Posted 08/03/06 05:23 AM Share Posted 08/03/06 05:23 AM reach in under the left hand kick board and unplug it hey presto Link to comment https://www.fordxr6turbo.com/forum/topic/23900-unichip-the-flick-of-a-switch/#findComment-357616 Share on other sites More sharing options...
TBO240 Member 628 Member For: 21y 9m 8d Gender: Male Location: Geelong Posted 08/03/06 05:31 AM Share Posted 08/03/06 05:31 AM TBO240 said: reach in under the left hand kick board and unplug it hey presto<{POST_SNAPBACK}>serious though if you unplug it ,it will run on the factory map.so it shouldn,t be to hard to slice in a switch to bypass the unichip depend if you are running bigger injector or not as it wouldn,t be adviserable to run on the factory map with bigger injectors. Link to comment https://www.fordxr6turbo.com/forum/topic/23900-unichip-the-flick-of-a-switch/#findComment-357622 Share on other sites More sharing options...
tab Sucker Moderating Team 32,303 Member For: 21y 18d Gender: Male Location: Brisbane Posted 08/03/06 06:26 AM Share Posted 08/03/06 06:26 AM TBO240 said: TBO240 said: reach in under the left hand kick board and unplug it hey presto<{POST_SNAPBACK}>serious though if you unplug it ,it will run on the factory map.so it shouldn,t be to hard to slice in a switch to bypass the unichip depend if you are running bigger injector or not as it wouldn,t be adviserable to run on the factory map with bigger injectors.<{POST_SNAPBACK}>I think that's what Christine was getting at, except rather than one "switch" you'd need sixteen of them. Link to comment https://www.fordxr6turbo.com/forum/topic/23900-unichip-the-flick-of-a-switch/#findComment-357647 Share on other sites More sharing options...
TURBO4LT Member 1,533 Member For: 21y 8m 25d Gender: Male Location: NSW Posted 08/03/06 07:00 AM Share Posted 08/03/06 07:00 AM TBO240 said: TBO240 said: reach in under the left hand kick board and unplug it hey presto<{POST_SNAPBACK}>serious though if you unplug it ,it will run on the factory map.so it shouldn,t be to hard to slice in a switch to bypass the unichip depend if you are running bigger injector or not as it wouldn,t be adviserable to run on the factory map with bigger injectors.<{POST_SNAPBACK}>I dont think it will run if you unplug it, its the bridge between the wires that have been intercepted and cut. Link to comment https://www.fordxr6turbo.com/forum/topic/23900-unichip-the-flick-of-a-switch/#findComment-357655 Share on other sites More sharing options...
cobrav8 Member 1,969 Member For: 20y 1m 19d Gender: Male Location: New Zealand Posted 08/03/06 08:03 AM Share Posted 08/03/06 08:03 AM You can definately get a swicth that can switch multiple wires at one click. I have seen connectors that can switch around 20 or 30 pinned plugs from one connection to another.Go and talk to a shop like Dick Smiths, and if they cant supply one, should be able to point you in the direction of someone who can. Link to comment https://www.fordxr6turbo.com/forum/topic/23900-unichip-the-flick-of-a-switch/#findComment-357678 Share on other sites More sharing options...
F6 UTE - Track Bound EVO III - Member 3,367 Member For: 20y 4m 28d Gender: Male Location: Strapped in and holding on Posted 08/03/06 12:24 PM Share Posted 08/03/06 12:24 PM (edited) It 'could' be done.There is a 'blank off' plug which APS sell for tuners. Plugs into the harness, it runs on the factory pcm/ecu.You could factor this into your harness, but what a job.. If you want 'instant power', get an exede with one 'map' with no values set in it, flick the switch to your second (modified ) map and you have a modified car. Edited 08/03/06 12:24 PM by F6 UTE Link to comment https://www.fordxr6turbo.com/forum/topic/23900-unichip-the-flick-of-a-switch/#findComment-357790 Share on other sites More sharing options...
