  • Site protagonist
  • Member For: 22y 4d
If someone gives me a manual with a good clutch and 370rwkw's on HPF's dyno I'll give you an 11 in a manual. :spoton:
Geea. :tease:
  • Replies 68
  • Toughest BA Turbo
  • Member For: 22y 4m 22d
Geea. :tease:
<{POST_SNAPBACK}>
Craig,
It's far easier said than done, and the odds are against you.
I assume that you're talking MT's, not typical street tyres.
You have 3 major things working against you:
1. slow gear changes:: assuming T56 you can't really change quick enough (for my liking). RIP shift may help a lot.
2. gearing: with a T56 & 3.73 diff you have a top speed in 4th of around 112mph at 5800 revs, so with 370rwkw you need to shift into 5th. 4-5 gear change is not a fast shift. With my 1 experience at WSID shifting into 5th at around 350m I found that given the time to change gear my speed didn't really increase in the last 50 metres. A 3.46 diff would give an extra 8mph over a 3.73 diff at 5800 revs in 4th.
3. low stock rev limit of 5800 revs: especially the impact of how fast you can go in 4th: increasing rev limit is really only useful if you are still generating good power, and better with modified turbo and cams. Another 1200 revs (say to 7000) would give another 16mph capability in 4th.
Brian
  • Member For: 20y 11m 19d
1st runs down the quarter in a manuel f6, (a person that has hardly run at the drags before) and he was pulling 1.89 60fts
with m/t's ,standed clutch,
detune the power under 4000rpm so you can leave the line doing a 1.8 60ft then let the power do the rest.
put that 60ft in front of your time you have already got and it will show a 11 sec run.
  • Member of team Kittens
  • Member For: 21y 2m 23d
  cdm said:
Gogo: Out of interest, what's your rev limit set at?
<{POST_SNAPBACK}>
At the moment the hard limit is at 6200rpm - but if I get serious in chasing this then this will lift to about 6500 - 6800rpm with some additional go which will require new rods in the motor as a minimum.
First step is to get the right clutch in the car - my launches are slow with little capacity to slip the existing organic unit I have limiting flexibility and ability to practice this.
Immediately my target is mid 12's, then we will see from there...
Cheers,
Ben.
  bcl said:
  geea said:
If someone gives me a manual with a good clutch and 370rwkw's on HPF's dyno I'll give you an 11 in a manual. :laughing:
Geea. :spoton:
<{POST_SNAPBACK}>
Craig,
Brian
<{POST_SNAPBACK}>
All correct,
I figure that if I do some work on the engine I would be looking at a capacity of nearly 140mph in fourth with the 3.46 diff @6800rpm.
Geea. :laughing:
<{POST_SNAPBACK}>
Who knows Craig... You might get an opportunity to give it a try... :whistle: Just not for a few months... :spoton:
Cheers, :spoton:
Ben.
  • Colossal Member
  • Member For: 20y 8m 22d
............If only I had more power
I can't do it captain! If I give her any more, the whole things gonna blow!!!!
  • Member For: 20y 2m 15d
<{POST_SNAPBACK}>
I'm assuming a 3.73 diff is not standard? as I can easily do 190KM in 4th...
  • Site protagonist
  gogo said:
Geea. :spoton:
<{POST_SNAPBACK}>
Who knows Craig... You might get an opportunity to give it a try... :msm: Just not for a few months... :tease:
Cheers, :tease:
Ben.
<{POST_SNAPBACK}>
Sounds good Ben I cant wait. :tease:
I also hear what Brian's saying and agree, it will be hard. Yes I'd wan't to be using MT's. Without them forget it. :tease:
Geea. :spoton:
